YZ 125 trouble
This is a discussion on YZ 125 trouble within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Well to start off I dont know too much about dirt bikes, and I'm having trouble with my 97' YZ125. ...
Old 05-07-2009, 03:38 PM
Last Online: 10-30-2009 03:49 PM
Default YZ 125 trouble
Well to start off I dont know too much about dirt bikes, and I'm having trouble with my 97' YZ125. Im running 93 octane with amsoil dominator at 44:1, NGK BR8ES plug. I was riding my bike just kinda shut down. Could it just be a fouled plug or what? I sprayed some starting fluid in the carb and it started right off but as the fluid burned off it died.
Old 05-07-2009, 05:12 PM
kwmotocrosspunk's Avatar
Im SOUNDERS Till I Die!
Last Online: Yesterday 05:44 PM
well i would start a mental check list
it takes spark, gas and comepression to make a motor run, it most likely is NOT compression, cause you would know it right away, your kick starter would basically fall down with out effort
it could be spark, pull out your spark plug, clean it off, put it back in the boot, and hold it against the side off the engine case and have some one kick it over, if your getting good blue spark, then it most likely isn't spark, but you could throw in a new plug for safe measures
that leaves gas for last, is your tank empty? seriously, its embarrassing but it saves hassle, if you have gas, check your connections to the carb, make sure your petcock is working fine, then check your main and slow jets in your carburetor
Old 05-07-2009, 06:57 PM
HELLDOG488's Avatar
Last Online: 05-19-2009 08:37 PM
ANOTHER MENTAL NOTE....
Never NEVER use starting fluid on a 2-stroke motor
Similar Threads for: YZ 125 trouble
LEM LX2 TROUBLE RMZDAD2007 Member Introductions 1 07-07-2008 01:59 PM
big trouble nathan 4-Stroke Motorcycles - Honda 5 09-06-2007 02:37 PM
tRoUbLe At tHe tOP!... RICHIE500 General Discussion 6 02-03-2006 04:21 AM
Carb trouble danpeltz 2-Stroke Motorcycles - Suzuki 6 02-10-2005 05:15 AM
I Anyone Having trouble .... OLDMXRACER 393 General Discussion 60 11-10-2003 09:56 PM
