Old 10-18-2012, 04:19 AM
Last Online: 03-10-2015 07:24 PM
Default Yamaha PW80 Not Running Right
Hi everyone
Back in January I pick up a 2007 Yamaha pw80 for $600 that need some TLC. I got it looking back to original condition but the engine has a problem.when I start it and run it cold it runs fantastic,exactly how it's suppose to run,but when I ride for a few minutes and it warms up it looses power when I pull the throttle and make a loud tingy noise and has very little power. I cleaned the carb twice,replaced the air filter, drainded the oil and put fresh gearbox and motoroil in it,cleaned the full tank and the filter on the fuel tap and I took the carb to a Yamaha dealership and had the float level set.i tryed putting the choke on but that just stalls the bike.
I done some research and I am now starting to think that it may be the piston,the rings or that It is getting way too much oil.
I'm really not sure and would really appreciate any help you guys have to offer!
Thanks,Tony
Old 10-18-2012, 04:16 PM
Last Online: Today 06:16 AM
Default OK
OK, do a compression check to see if the top end is shot. Low compression will give off signals of being too rich and will loose power when warm. Also checl the exhaust silencer to be sure it is not clogged up or needs repacking.
Old 10-18-2012, 11:52 PM
It is sure acting rich. Those can run a really long time in a set of rings if the don't get run out of oil too many times. That one should have a removable float seat. Make sure the gasket under it of the needle isn't leaking. Listen to paw on the plugged rchsust
Old 10-20-2012, 02:07 AM
I replaced the exhaust silencer on it about 2 months ago with a fmf powercore 2. I also gave it a compression test and it has good compression. I'm yet to check the gasket under the needle in the carby
Old 11-06-2012, 09:02 PM
Last Online: 11-09-2012 08:06 PM
I think the pw80 has a heater on the carb.
Usually when you start the 80 you need the choke and it will run like crap for a little bit COLD. When the heater coil warms up then I lip the choke off and off he goes.
Check the wires going to the carb.
Old 11-07-2012, 12:00 AM
I'll try that, whenever I put the choke on the bike sounds like its running out of fuel and unless I hold the throttle on it stalls.
Old 11-07-2012, 04:50 AM
Default No
NO, NO, NO.... There is no heater in the carb. It is a very simple unit with very few parts. As Oss suggested you may have a leak at the float and the gasket.
I would also want to know exactly what the compression numbers were when you checked it and said it was good.
The power core silencer may also be an issue as it may have the intake and exhaust out of ballance now.
Old 11-09-2012, 06:07 AM
I took the carb apart and checked the gasket and its fine. I also checked the float and its not leeking or anything. Ive got the carb, float and jets soaking in carb cleaner over night and ill assemble it tomorrow and give it a test ride. When i checked the compression i dident use a gauge i just put my thumb where the spark plug goes and pushed on the kick start lever and my thumb blew off the hole.
Old 11-09-2012, 06:32 AM
arnego2's Avatar
Last Online: 01-09-2018 02:14 PM
thump is clearly not enough to test compression. 120 psi is hard to feel
Old 11-09-2012, 06:39 AM
Default ?????
You need to do the compression test with a guage.
FYI: The jets will have to be cleaned better than just with a soaking. Todays fuels leave a hard deposit in them that looks clear, but is actually reducing the flow of the jets.
Similar Threads for: Yamaha PW80 Not Running Right
PW80, Yamaha, no spark Vince 69 2-Stroke Dirt Bikes - Yamaha 1 06-29-2012 09:03 AM
98 Yamaha PW80 Just Quit missy 2-Stroke Dirt Bikes - Yamaha 2 03-20-2012 12:07 AM
Yamaha PW80 For Sale GREAT STARTER BIKE pain995 Classified Ads 1 03-12-2009 02:58 PM
Yamaha PW80 project for sale -$50 OBO Andershoberg Classified Ads 0 11-07-2008 06:03 PM
01 Yamaha PW80 for Sale or Trade ccra92 Classified Ads 2 12-30-2006 03:59 PM
