Yamaha play bike is now a Yamabog? Help
This is a discussion on Yamaha play bike is now a Yamabog? Help within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Okay, this problem has forced me to ask for some help, I have a 99' rt100 that has good compression, ...
Old 01-01-2005, 03:07 AM
Hotrodtodd's Avatar
Last Online: 10-30-2005 11:53 AM
Default Yamaha play bike is now a Yamabog? Help
Okay, this problem has forced me to ask for some help, I have a 99' rt100 that has good compression, strong healthy spark, good reeds, have gone threw the carb 20 times and looks clean and proper. I have had this bike for years and has never given me the slightest little hickup, it seems to come and go, the bike revs up to full throtle at idle, the slide is free moving and doesnt make a difference to kick it down, idle is affected too, it almost seems like there is a vacume leak and the carb is getting too much air? This was happening when the motor was in the bike, since then I have built a gocart with it and thought that it was crap in the carb and would fix it later. Well the problem is still there in the gocart too. This bike/motor is 100% stock and I just cant figure it out? Any help will be appeciated...
Old 01-01-2005, 09:09 PM
OlSchoolFool393's Avatar
Older than DIRT
Last Online: 03-17-2010 10:09 AM
Default Re: Yamaha play bike is now a Yamabog? Help
If you have the same pipe on it check to see if it has a rat nest built in it I had this problem once , In a bike that set up?
Old 01-01-2005, 09:40 PM
Vintage Dave393's Avatar
ATM History Professor
Last Online: 10-18-2009 07:09 PM
  • Bad crank seal on the ignition side
  • Base gasket leak
  • Head gasket leak
  • Loose spark plug
  • Crack in the carburator (ask Big Maico393 about this one: )
  • Air leak in center case (gasket or crack)
  • Extremely lean or clogged pilot jet
Similar Threads for: Yamaha play bike is now a Yamabog? Help
1984 YAMAHA IT 200? anybody know this bike? cycleryan General Discussion 30 07-01-2009 12:24 PM
play around bike? DUDEONAYZ125 General Discussion 15 06-25-2008 08:19 AM
2006 YAMAHA::PICS OF MY NEW BIKE! MxMike393 4-Stroke Motorcycles - Yamaha 36 11-16-2005 10:14 AM
I need a play bike thumpers474 General Discussion 4 10-27-2004 07:04 PM
Wats your Fav play bike CrMxer125 General Discussion 18 08-22-2003 11:13 AM
