Whats Wrong?? GRRrrRRRRrrRrrRrR HELP!!
This is a discussion on Whats Wrong?? GRRrrRRRRrrRrrRrR HELP!! within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; hey guys, i left a post on here last wed stating i was getting y first 250, its a 1990 ...
Old 06-26-2007, 07:49 AM
Last Online: 08-10-2007 10:59 AM
Angry Whats Wrong?? GRRrrRRRRrrRrrRrR HELP!!
hey guys, i left a post on here last wed stating i was getting y first 250, its a 1990 model not a 94 like i was led to believe, neway up until yesterday it was running sweet as a nut, bit hard to kick but bumps easy enough then the thing just up and died on me! I was trying to turn around in a tight space, didnt give it enough revs and it stalled since then it hasnt started. theres fuel getting through and the air filter isnt blocked but it isnt sparking. is there a common fault on these models or am i missing something obvious? plz guys im desperate 4 help, its a sin 4 her to be sat there with no life in her!!
any help would be GREATLY appreciated
Cheerz guys
Donk
Old 06-26-2007, 07:56 AM
Squigs's Avatar
Punk Rock Rider
Last Online: 08-28-2009 02:28 PM
Default Re: Whats Wrong?? GRRrrRRRRrrRrrRrR HELP!!
Well if you aren't getting any spark then my suggestion would be to check your plug (i.e. gap, color), your plug wire as well. Was it running rich or lean when it quit working? Is it hard to kick now that it can't start or is it easy now? Try these things and then let us know whats up. I will try and help as much as I can and I know that some of the wiser ( old guys ) will be in here to help soon as well.
Old 06-26-2007, 08:02 AM
the plug lead was a bit frazzled when i unscrewed the cap so i sliced a small part (10mm) off the end to make a better connection, cleaned the plug(which is off a fiat by the way! but i didnt think that would be the problem as it run sweet with it for a few days) and the kick is the same as it was as to running lean or rih, it wasnt smoking as far as i could see and i used the ratio 32:1 as posted on here, do you think it could be electrical?
thanx for the quick reply!
Donk
Old 06-26-2007, 08:11 AM
Squigs's Avatar
Punk Rock Rider
Well if you don't have any spark then it is for sure an electrical problem. If you are using a plug from a Fiat then I would say that you should get the right plug for the bike. Certain plugs burn hotter then others and they are designed to fit into the cylinder head. I was wondering if it was running rich or lean because to rich will foul your plug. To lean and you will detonate. What color was you plug when you pulled it out and cleaned it? I suggest that you first get the right plug for the bike and get back to us.
Old 06-26-2007, 08:18 AM
ok will do, shud i be going for the dr8eg?
Old 06-26-2007, 08:24 AM
Squigs's Avatar
Punk Rock Rider
NGK BR8EG is what I run. I think that most people run the NGK BR8EG plug. If the Fiat plug that you had in there was longer and went into the cylinder too far then you could have been doing damage to the piston. You have to be careful with that kind of stuff. One little spark plug can ruin your top end. I hope that I have been some help to you.
Old 06-26-2007, 08:36 AM
Br8eg, thats wot i meant lol!
cheerz m8, ur a star already rung south wales superbikes and they got them in stock, on my way to pick 1 up now!!
fingers crossed its just that eh?
cheerz agen
Donk
Old 06-27-2007, 09:54 AM
ok definitly not the plug, jus spent £7.50 on a BR8EG and its exactly da same, ne ideas?
cheerz guyz
Donk
Old 06-27-2007, 10:04 AM
DRGSin393's Avatar
Super Moderator
After you messed with the plug wire did you end up getting a spark at the plug?
Similar Threads for: Whats Wrong?? GRRrrRRRRrrRrrRrR HELP!!
whats wrong with my 2003 yz 125 ajbennefield 2-Stroke Motorcycles - Yamaha 7 01-16-2008 06:04 AM
whats wrong? hondamxrider63 2-Stroke Motorcycles - Honda 3 11-14-2007 08:09 PM
Anyone Know Whats Wrong? Fireman87 2-Stroke Motorcycles - Honda 5 11-04-2007 05:02 PM
whats wrong???????????? wheelieking ATV/UTV - General Discussion 16 12-07-2004 02:02 PM
whats wrong?? 98 cr crdemon 2-Stroke Motorcycles - Honda 31 03-21-2004 06:46 PM
