What's up with the Yamadog front brake line routing?This is a discussion on What's up with the Yamadog front brake line routing? within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Originally Posted by Satch0922
gotta love fart humor....dude how did you come up with that? Not that Harleys would make ... |
#21
No....not at all. lol. |
#22
| [QUOTE=nick novice][QUOTE=mtk] Quote:
As for the "Fog Hollow" bit, there are places called ___ Hollow. Remember the Headless Horseman? He lived in Sleepy Hollow. Sounds like a place to me. You also said "place," not "shop." Last I checked, towns are commonly referred to as "places." Sorry I can't divine your meaning from unclear wording. As for the ATC, it was mid-engined, which at the time was a new thing. In fact, the trike itself was a new thing. Honda developed the idea of a big-tired offroad vehicle with three wheels and patented the engine location of said vehicle. The Yamahas of the time had the engines closer to between the rear wheels. The Kawasakis had their engines biased more toward the front. If you look at a photo of all three, it's clearly discernable. As a result, the Hondas had the best handling, by far, of any of them. Look at Honda's new streetbike suspension with the top shock mount attached to the swingarm. It's patented. Look at Dr. Rob Tuluie's Tu-lar-is roadrace bike; he's got a half dozen or more patents on his rear suspension design. At least in the US, there is NO requirement that the idea works or even obeys the laws of physics. There are at least a dozen "perpetual motion" machines that have been patented in the US. Nevermind that they violate the laws of thermodynamics, they're still patented. The idea doesn't have to be good, it just has to be new. In Honda's case, it was both new and functional, so they protected it. As a result, they owned the ATC market. As I recall, it wasn't until the last year before ATCs were pulled from the market that Yamaha and Kawasaki came out with a proper mid-engined sport trike. The Yamaha model, the Tri-Z 250, has to be one of the most rare ATCs of all time since by that point Honda's ATC250R owned the market segment. |
#23
| Hey I'm going to split this up so that it's not cobbled together in the end. [QUOTE=mtk] Quote:
[QUOTE=mtk] Quote:
[QUOTE=mtk] Quote:
#24
#25
One thing that is a shame is the changes in the US Patent Office over the years. Patents used to be researched not only to make sure they were new ideas but also to make sure they were functional and actually worked. The latter no longer happens. That's how you get patents for perpetual motion machines and other such fantasy items. |
#26
| Yeah, the lawyers got a third or maybe even half. But $170 million is still a nice pile of money. If you can fill a swimming pool with $100 bills, it's enough for me. |
#28
| I guess you guys didn't hear MTK is a lawyer/engineer/esquire. The CR routing works because it's has less resistance than the tight radius on the bottom of the fork used by Yamaha. Actually, the motoman393 website has a detailed section for making the conversion. |
#29
#30
As for that being the reason that the CR routing works better, I don't buy it. Resistance doesn't really come into play in hydraulics because you're really not moving much fluid. Every banjo bolt on the system is a 90 degree turn and a pretty complex path for the fluid to follow and it doesn't hurt performance. However, the Yamaha routing would be real PITA to get bled properly and I'll bet that is the main problem with that routing. Not to mention exposing the line to more damage. Besides, everyone knows Honda is just better, period. |
#31
#32
| Removing it changes everything. I don't disassemble the bike to bleed the brakes on any bike, street or dirt, unless I absolutely have to do it. I have a MityVac so that's what I use to bleed any hydraulic system. Works better than that "pump it and hold" crap, that's for sure. |
#33
#34
#35
The extra line may make a difference. I keep forgetting that the stock lines are rubber, not stainless, so they do expand when you apply the brake (hold the line in your hand and pull the lever and you can feel it). That will cut down the power and feel of the brake a bit. |
#36
| The reason CR style brake routing it better is simply because the fluid has a shorter cable to run through so you get better feel and less spongyness. |
| Front Brake line | basanch73 | 4-Stroke Motorcycles - Yamaha | 5 | 12-17-2007 04:02 PM |
| 05 yfz450 jetting?'s/ front brake line problems? | daddyed73 | ATV/UTV - Yamaha | 5 | 10-23-2006 02:14 AM |
| Galfer steel braided front brake line | cadman | Drivetrain, Tires & Suspension | 1 | 05-10-2006 12:14 AM |
| Galfer braided front brake line problems | cadman | 2-Stroke Motorcycles - General Discussion | 3 | 05-09-2006 11:04 PM |
| Needed. Front brake line from a WR-426/250 | b-bike393 | MC & ATV Parts & Accessories | 3 | 09-22-2004 08:45 AM |
