what mm is the nut on the rear axle of a yz125?
This is a discussion on what mm is the nut on the rear axle of a yz125? within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I got a 2000 yz125 and dont have a large enough socket to fit the bolt that holds the axle ...
Old 11-01-2004, 04:29 PM
mxrider's Avatar
Last Online: 10-20-2006 06:17 PM
Default what mm is the nut on the rear axle of a yz125?
I got a 2000 yz125 and dont have a large enough socket to fit the bolt that holds the axle on..what MM is the nut that is on the end of the rear axle??..thanks..(for example I guess its around a 22mm socket that fits it not sure tho)
Old 11-01-2004, 05:13 PM
zuki's Avatar
Last Online: 02-14-2007 02:12 PM
Default Re: what mm is the nut on the rear axle of a yz125?
You could always just use a cresent wrench.:
Old 11-01-2004, 05:31 PM
KTM250rm393's Avatar
Hey Coach
Last Online: 05-20-2007 11:47 PM
I believe its a 27 mm which is the same size as the front sprocket nut
Old 11-01-2004, 05:58 PM
Last Online: 01-08-2009 06:11 PM
Just measure it !
Old 11-01-2004, 06:08 PM
psyklone393's Avatar
...dress for the crash...
Last Online: 03-27-2006 11:53 AM
i'm sure that rick is correct. on my '99 yz125 it's got a 27mm on the rear. or if you wanted to round off the nut pretty good and have little chance of getting it off easily, you could always use a crescent wrench. :
-Z
Old 11-01-2004, 07:47 PM
mxrider's Avatar
Thanks guys I knew u would help me out!....I have a cresent wrench but it isnt big enough to fit around the nut and I heard those arent good for tight things..those are only good for things that u dont gotta tighten alot..
Old 11-01-2004, 08:08 PM
Dirtbiknkid's Avatar
Small riders dream BIG!
Last Online: 01-27-2009 08:40 PM
you can check the manual it should say.
Similar Threads for: what mm is the nut on the rear axle of a yz125?
rear axle bearings trailrider894 ATV/UTV - Honda 1 03-25-2008 04:58 PM
Can't get rear axle out RedRaider General Discussion 15 01-28-2006 09:29 PM
Rear Wheel Axle Problems 3 stroke General Discussion 15 11-16-2004 09:48 PM
What size is rear axle nut? 30mm? RedRider250R General Discussion 12 04-27-2004 10:35 AM
'97 RM 250 rear axle Richhest 2-Stroke Motorcycles - Suzuki 4 11-03-2003 02:16 PM
