what is the compression pressure in 02 yz125
This is a discussion on what is the compression pressure in 02 yz125 within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; need to do a leak down test anyone know whats the PSI ?...
Old 03-03-2004, 10:09 PM
Last Online: 03-15-2009 03:26 AM
Default what is the compression pressure in 02 yz125
Old 03-05-2004, 12:28 PM
Faded's Avatar
Default Re: what is the compression pressure in 02 yz125
Generally 5 psi is needed. The piston needs to be at BDC to allow the transfer ports to link the cylinder bore and the crank case. The bleed down rate should not exceed 1psi per minute.
Old 03-05-2004, 01:10 PM
KTM250rm393's Avatar
Hey Coach
Last Online: 05-20-2007 11:47 PM
I just did a topend job on a 03 YZ125 last week.
It started out at 115 lbs. before the topend and after break-in it went to 145 lbs.
Old 03-05-2004, 06:17 PM
thanks for the information
Old 04-16-2004, 11:25 PM
YZGreg's Avatar
You can call me ROBOMAN
Last Online: 04-08-2006 12:32 AM
"It started out at 115 lbs. before the topend and after break-in it went to 145 lbs."
Thats not much pressure for a new bike. My 84 yz250 had
150 lbs. when I first put the rings in, now its got 165 lbs.
Old 04-16-2004, 11:56 PM
Aus_Rider_22's Avatar
Mod From Down Under
YZgreg: That's because yours is a 250!
Old 04-17-2004, 03:30 PM
YZGreg's Avatar
Iv'e seen 125's with 200+lbs, but I guess that 125 is stock. And my 250 is 20 years old! but I guess people that ride 125's are too light to kick over a high compression bike?
Old 04-17-2004, 05:29 PM
Mod From Down Under
I can kick over my friend's CRF450R easy. Hot or cold.
Old 04-17-2004, 06:06 PM
YZGreg's Avatar
why do you ride a 125 then, wouldn't you rather have a bike that lasts longer and has more power?
Old 04-17-2004, 06:29 PM
MATTXR250R's Avatar
Retired ATMer
Last Online: 08-27-2008 08:35 PM
When I rebuilt the topend on my CR250R...About 2 months after I did it I checked it and it cranked out 188 PSI.
Similar Threads for: what is the compression pressure in 02 yz125
1986 yz125 compression (psi) Moto man26 2-Stroke Motorcycles - Yamaha 3 09-01-2008 04:28 PM
More YZ125 rebuild/compression problems dellaquila 2-Stroke Motorcycles - Yamaha 65 02-28-2008 01:11 PM
2000 YZ125 Engine Compression Reading mat827 2-Stroke Motorcycles - Yamaha 7 10-16-2007 10:03 PM
yz125 compression test Moto man26 2-Stroke Motorcycles - General Discussion 2 12-13-2006 07:12 AM
Compression Test Results(YZ125) matt_jasmine General Discussion 10 10-30-2005 05:03 PM
