water from radiator overflow hoseThis is a discussion on water from radiator overflow hose within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; bought a yz250 1997 from a friend. when i first tested it saw there was a 300-400 cc water missing ... |
| bought a yz250 1997 from a friend. when i first tested it saw there was a 300-400 cc water missing in the radiators. added water and saw the water driping from the overflow hose. i tot i addad to much but the water continued to overfow. i checked the cap and its fine and i installed a new head gasket yesterday - didnt checked it after the new head gasket . my friend did a new piston n rings a 20 hours ago so i guess no need for new piston or rings - anything else should i check or the new gasket will solve it? dont have time to check it till the week end. |
| If it is coming out of the overflow hose then it has to be getting by the cap (assuming it is set up like my 99wr). I dont think the head gasket would make any difference if it were coming out the over flow. |
It may have been filled with tap water and now be slightly clogged from the minerals.Give it a flush and see if it helps. |
| Cramps - too much water? | cjacobs | General Discussion | 24 | 09-03-2005 06:06 PM |
| water leak on 2003 kx 250, need help. | bigguns30 | General Discussion | 2 | 07-27-2004 08:22 PM |
| anti freeze additive (what to use) | dirtcrf | 4-Stroke Motorcycles - General Discussion | 70 | 04-19-2004 08:17 PM |
| Another Prestone coolant question | MATTXR250R | General Discussion | 51 | 03-19-2004 02:57 PM |
| Lemon Law on ATV? Recon - ATV minus water | 4wheelinEastTN | ATV/UTV - Honda | 4 | 03-08-2004 09:54 AM |
