v-force or boyesen reed's?
This is a discussion on v-force or boyesen reed's? within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I have a 2000 yz125 and was wondering what would give me better low-end. A v-force or a boyesen reed? ...
Old 07-13-2004, 06:48 PM
1kx100's Avatar
Last Online: 07-25-2007 04:05 PM
Default v-force or boyesen reed's?
I have a 2000 yz125 and was wondering what would give me better low-end. A v-force or a boyesen reed? And when you use these do you have to run race gas?
Old 07-13-2004, 07:08 PM
YZGreg's Avatar
You can call me ROBOMAN
Last Online: 04-08-2006 12:32 AM
Default Re: v-force or boyesen reed's?
Well reeds don't change the compression ratio so you wouldn't need to use race gas. I've only used boyesen so I can't really compare the two, boyesen's have been around for a very long time so they're proven to be good reeds. Are you talking about the boyesen rad valve or just the reeds? Because v-force reeds are on a performance cage I don't think they fit the stock cage.
But you can buy boyesen's to fit a stock cage.
Old 07-14-2004, 04:13 PM
easyas123's Avatar
Last Online: 05-19-2005 11:07 AM
I have used both on my 99 yz 250 by far if you want the bottom end response you need to go with the v force reed valve system.
You get a new reed cage which has more depth and the valves have ore surface area and they are stiffer to atomize the fuel better to get a crisp bottom end response so hold on tight.
The only thing you need to keep in mind is you may have to go down in the main jet do to the valve system tends to run richer so you will have to take a look at the plug for that golden brown look. Good luck and try not to rip off the back tire.
Old 07-14-2004, 06:05 PM
Roostman's Avatar
"Roostman, lays an egg!"
Last Online: 04-17-2009 03:59 AM
I too have had only good results using Boyesen. Like Greg said, they have been around forever and have proven to work (think 'McGrath' as well as many others over 30 years). I havent tried the VForce stuff but many swear by them as well. One great thing about Boyesen is that they offer a 100% money back satisfaction guarantee on their products, I dont think MotoTassinari does.
Old 07-16-2004, 05:31 PM
yamaha man 69's Avatar
Last Online: 09-13-2004 12:42 AM
i have a 1997 yz 125 and i run the boyesen rad valve its great for top end power but not so much low end i dont run race gas all the time and it runs great
Old 07-16-2004, 05:34 PM
thoryamaha22's Avatar
Last Online: 02-04-2006 10:15 PM
i have a 2003 YZ 85 and i run a boyesen it that and it works great i also have a 2003 YZ 125 and i run a v-force in that and it runs great also and i didnt have to do anything with the gas.
Old 07-16-2004, 08:12 PM
Aus_Rider_22's Avatar
Mod From Down Under
Last Online: Yesterday 07:39 AM
I think from what people have said they both improve reponse just in slightly different RPM of the power.
Here are some dynos for some interesting reading!
Of course it was from the Boyesen site.
Here are some jetting specs for ya bike!(I have the same!) thumb:
Model: YAMAHA Main Jet Jet Needle Clip Pilot Jet Air Screw
Main Needle Clip Pilot Air Scr
YZ125 Stock 350 6DHY53-75 2 35 2
YZ125 Power Reed Part # 694 340 6DHY53-75 2 35 1.5
YZ125 Pro Series Reed
Part # Pro-141 340 6DHY53-75 2 35 1.5
YZ125 Rad Valve Part # RAD-33E 340 6DHY53-75 2 35 1.5
Old 07-16-2004, 10:07 PM
psyklone393's Avatar
...dress for the crash...
Last Online: 03-27-2006 11:53 AM
i run the vforce in my '99 yz125 and i love it. to be fair, i've never used the boyesen reeds or rad valve. a buddy of mine put a vforce on his '99 yz250 and could tell quite a difference in the way it pulls off the bottom as well as a much crisper throttle response. it's a performance bolt-on i'd recommend, however i would not recommend using the gasket that comes with the vforce. it's been prone to air leaks. instead, use a gasket maker material like rtv or yamabond (rtv is cheaper and works just as well) to seal the reed cage to the intake.
cheers,
-Z
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: v-force or boyesen reed's?
Reed's '06 DPW General Discussion 20 11-26-2005 02:54 PM
V-force or Boyesen?? alex83 2-Stroke Motorcycles - General Discussion 63 11-24-2005 12:48 AM
REED'S LID FOR UNADILLA !! Satch0922 General Discussion 12 07-17-2005 08:13 PM
delta v-force 2 vs. v-force 3??? zuki General Discussion 2 08-26-2004 10:23 PM
V Force Reeds or Boyesen Reeds mattdcs 2-Stroke Motorcycles - General Discussion 54 07-11-2004 11:38 AM
vB.Sponsors
