TROUBLE!!! PLEASE READ
This is a discussion on TROUBLE!!! PLEASE READ within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; But I think what woody and oring were sayin was that the higher RPMs=more fluid(gas and oil)circulation,which cools the moter ...
Old 09-25-2004, 02:19 PM
zuki's Avatar
Last Online: 02-14-2007 02:12 PM
Default Re: TROUBLE!!! PLEASE READ
But I think what woody and oring were sayin was that the higher RPMs=more fluid(gas and oil)circulation,which cools the moter down more.
Old 09-25-2004, 06:34 PM
twoofeach's Avatar
AKA clicea
Originally posted by pragmatic
Guys, I understand the lack of air flow will contribute to a hotter running bike.
What I don't quite agree with is the idea of running at higher RPM's (on the pipe) at lower speeds equals cooler temps>Same air flow.
I see what you're saying Pragmatic. I agree with you. Of course, the higher RPM's are going to make the engine run hotter. That's more friction. I can't find the terminolgy to describe what I am saying. In other words, when my bike starts spitting out the coolant, I usually turn it off and let it cool down or go through the gears at low to to moderate RPM's. That gets the coolant churning and plenty of much needed air flow. That usually solves the problem for me.
Old 09-25-2004, 08:09 PM
pragmatic393's Avatar
..Thats, Mr. Spode to you!
Last Online: 11-12-2009 01:21 PM
Exactly! Thats the same thing I do with my 426.
I would not think the increased flow in oil/gas & coolant would contribute to lower engine temps without the air-flow.
I guess what I'm trying to say is> I think the fluid flows are adequate at idle (putting around) and would result in lower temps (less friction) and would be less damaging than keeping the bike on the pipe (higher RPM's) at the same speed.
Fouled plugs is another story
Old 09-25-2004, 08:58 PM
Silver_Fox's Avatar
Wut the?
Last Online: Yesterday 11:50 PM
yamracer58
in the old days i had '85 rm125 that had the same issues as your bike, when I disasembled it the rings were cracked and one ring had a little chunk missing. Without hearing yours run I would say it sounds kinda how mine did, however the old '85 had no power valve.
Old 09-25-2004, 09:02 PM
Aussie@Down Under!
Last Online: 01-22-2006 09:02 PM
Don't forget that the coolant flowing in the barrel is sent around by a water pump!!
If your motor is not spinning the coolant won't be travelling at a fast enough rate!
It probably takes a combination of factures to cook a motor including where your riding ie Deep sand dunes.
I don't know if fluid flows at idle rate are too effective. If you let it idle for a long time you will boil your coolant!
Hell what would I know! only going on what this machinist told me and the damage done to my bike! The old bloke has been racing bikes road/trail for 30 years, good enough machinist to fix Helicopters, Is where everyone takes there stuffed up motors,
I think i'll stick with what he said!
Definately do what Blitz said!
Good luck!
Similar Threads for: TROUBLE!!! PLEASE READ
big trouble nathan 4-Stroke Motorcycles - Honda 5 09-06-2007 02:37 PM
EVERYONE READ THIS Very Good Read redrider4 General Discussion 11 02-13-2006 08:35 PM
tRoUbLe At tHe tOP!... RICHIE500 General Discussion 6 02-03-2006 04:21 AM
TROUBLE DOWN UNDER...a must read..i'm serious koda247 General Discussion 7 01-23-2006 11:17 AM
I Anyone Having trouble .... OLDMXRACER 393 General Discussion 60 11-10-2003 09:56 PM
