Old 03-31-2010, 06:42 PM
Last Online: 05-17-2010 10:01 PM
Default Tire Size(Please Help Fast!!!!!!)
my rear tire is 100/90-19 what does it mean????
Old 03-31-2010, 07:14 PM
crfjedi393's Avatar
Last Online: 03-31-2015 09:33 PM
The 100 and the 90 are millimeters. The 19 is inches. 19 is your rim size. 100 is how wide your tire is and the 90 is how tall it is from rim to knobby.
Old 03-31-2010, 08:22 PM
Will i need to get a new rim if i got a 110/90-19 size tire
Old 03-31-2010, 09:38 PM
The 100 is how wide the tire is in millimeters.
First number (100) is the width, second number (90) is the percentage of the height (Thickness) based on the width, third number is the rim size.
Example- If a tire was 100mm wide, 90% of that would give you a 90mm height.
The most important thing is the rim size, 19 means 19, nothing else will fit.
You can play with larger & smaller width tires, but check your owners manual- going bigger or smaller can adversely affect your handling & traction.
And then there's Michelin- sizes of all their own making..
Old 04-01-2010, 06:26 AM
Ekholm's Avatar
Last Online: 06-03-2013 06:19 AM
Ditto, Michelin does do their ownthing fo sho.
A 110/90-19 will fit on the rim for a 100/90-19 but the 110 IS a wider tire and will be a little tougher to get on the rim.
Old 04-02-2010, 07:44 PM
What About Sand tires
Old 04-02-2010, 08:01 PM
I think they all make up their own sizes. some almost have seemed like they meant their measurements to be taken without consideration of the knobs.
when you say sand tires are you talking about a knobby type or a paddle type?
Old 04-02-2010, 09:24 PM
Paddle Tires
Similar Threads for: Tire Size(Please Help Fast!!!!!!)
Tire size KKXR400R General Discussion 5 07-31-2007 08:21 AM
03 CR250r tire size dklassen 2-Stroke Dirt Bikes - Honda 7 12-14-2006 06:49 PM
tire size help kickindirt114 General Discussion 2 01-08-2006 06:49 PM
Tire size 99kx250rules General Discussion 3 03-16-2005 07:55 PM
What Tire size? bates393 4-Stroke Dirt Bikes - Honda 11 12-24-2003 08:36 AM
