throttle clip....This is a discussion on throttle clip.... within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; does anyone know how to remove the throttle needle from the slide cuz i cant seem to do it without ... |
| does anyone know how to remove the throttle needle from the slide cuz i cant seem to do it without damaging it. im trying to see where the clip is at for my adjustments and plus writing down everythig for later references. the guy i bought it from wasnt completely truthful ya know? thanks. i know that ive been posting alot but im new to all this and needing "alot" of help. shop fees are crazy these days. |
| Take the top of the carb off, pull the slide out, remove throttle cable and look down into the top of the slide. You will see a 6MM headed screw looking thingy. Remove that and the needle will come right out. Scott |
| ok, but what about the spring?, its like stuck in the slider or is that suppose to be like that? i guess ill get to it once the kids stop driving me crazy,lol. p.s. is the needle suppose to wiggle freely? ---------- Post added at 02:53 PM ---------- Previous post was at 01:50 PM ---------- the two hoses on top if carb., whats the purpose of those? i tried adjusting the carb again and put it back on bike without the tubes and slider in but its still leaking like crazy..... ![]() Last edited by reeseyz125; 05-06-2009 at 03:52 PM. Reason: typo |
| If its leaking that badly it may be the float at the btm of the bowl. It can sometimes get gummed up and stick. Pull the 4 brass screws off the btm and see if the float moves freely? I Good luck |
| Hey bud, Go on Ebay and get yourself a rebuild kit for your carb ($20 shipped). Then rebuikd the carb to spec, download a manual for your bike [Only registered and activated users can see links. ] , then chuck a new plug in it. If you are getting a wet threads but a dry core then you are set right or maybe even lean, there are recommendations in the manual of what to look for. Then your carb will be rebuilt and shouldnt leak, then you will also know that you have new needls and jets etc in the carb and it will be fine for a year at least, unless you are racing then it will need more maintenance, etc. its truly your best bet at this point because something is wrong and it sounds like it could be a worn jet, which happens at which point it will be flooding the bowl and then it is designed to expel the extras which for oyu is all the time. Just my two cents! Goodluck! |
| cir clip pliers which one | kxrdr65 | 2-Stroke Motorcycles - Kawasaki | 3 | 06-20-2006 11:36 AM |
| Small Video Clip of me :-) | Kirtwell | Photo & Video | 27 | 06-19-2006 08:35 AM |
| Clip of me Jumping a triple | MxMike393 | Photo & Video | 15 | 05-10-2004 09:36 AM |
| Clip:Me almost wreck | MxMike393 | Photo & Video | 21 | 04-14-2004 12:09 AM |
| 30 second video clip, big table | psyklone393 | Photo & Video | 27 | 01-03-2004 11:41 AM |
