throttle cable problems!
This is a discussion on throttle cable problems! within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I have a 2000 yz125 and the throttle cable got stuck open. I bought a new throttle cable and housing.(broke ...
Old 12-21-2004, 10:38 AM
1kx100's Avatar
Last Online: 07-25-2007 04:05 PM
Default throttle cable problems!
I have a 2000 yz125 and the throttle cable got stuck open. I bought a new throttle cable and housing.(broke when I crashed) And put them on, but now it feels like it isn't getting enough gas. I takes a long time to rev. Like I have it at 3/4 throttle instead of full throttle. Is there an adjustment that I can make to get it more gas? (if that is even the problem) I think there is one by the housing and where it goes into the slide, but i am not sure.
Old 12-21-2004, 11:02 AM
Silver_Fox's Avatar
Wut the?
Last Online: 11-19-2009 11:50 PM
Default Re: throttle cable problems!
Take the carb off, twist the throttle and check if the slide is opening all the way.
Old 12-22-2004, 01:27 AM
Aus_Rider_22's Avatar
Mod From Down Under
There are 2 adjustment points on your bike.
The first one being up on top of you handlebars, just near your throttle wheel. There will be 2 nuts covered by a rubber cover directly above master cylinder.
Take cover off and loosen nut so that the other can be adjusted. This is where you can adjust the throttle cable take-up. Try this and see if it helps it.
If not, the second adjustment point is directly above your carby. Just below a rubber cover are 2 nuts. Again, adjust them accordingly and this should fix your problem.
Hope this helps.
Please let me know if you have any other questions.
Similar Threads for: throttle cable problems!
Throttle cable ?????? Beans 2-Stroke Motorcycles - Honda 12 03-21-2009 01:18 PM
Throttle cable assembly jmdsurf45 General Discussion 1 02-04-2008 09:26 PM
Top throttle cable frozen in carb cowboyona426 4-Stroke Motorcycles - Yamaha 3 07-05-2007 10:32 PM
KX500 throttle cable removal mtk 2-Stroke Motorcycles - Kawasaki 6 03-06-2005 07:19 PM
Need Help with a 99 YZ 400 Throttle cable (Quick) lacofdfireman 4-Stroke Motorcycles - Yamaha 4 05-20-2004 07:06 AM
