THIRD TIME
This is a discussion on THIRD TIME within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I had been posting previously. Look at "Leakdown Test" '02 YZ125. Wristpin sides of piston melted. Electrode on plug melted. ...
Old 07-30-2004, 07:47 AM
Last Online: 10-05-2004 08:41 AM
Default THIRD TIME
'02 YZ125. Wristpin sides of piston melted. Electrode on plug melted. 1st full tilt run after top end rebuild, same thing. Checked everything I could think of. Leakdown test, good, sprayed starting fluid all over motor, no rpm rise, changed crank seals anyway, had carb checked out and cleaned, checked timing, dial indicator and everything. checked reeds, good water flow, new gas mix, B8ES plug. Only thing I have left is power valve. Checked for free movement and linkage, everything looked good.
Anybody know if PV malfunction can cause an extremely lean condition. I don't think so but I'm at wits end.
Sorry for the long post, think I need counselling. This makes the third time it has melted!
Old 07-30-2004, 07:59 AM
Aus_Rider_22's Avatar
Mod From Down Under
Last Online: Yesterday 07:39 AM
Default Re: THIRD TIME
There are a few different things to look at.
May I ask how you warm your bike up? And for how long?
Check here also: [Only registered and activated users can see links. ]
Old 07-30-2004, 08:14 AM
Stangmata50L's Avatar
Last Online: 10-05-2008 09:55 AM
I'm going through nearly the same issue with one of my snowmobiles.
I have $600 into a motor that has moved 50 miles in 3 years.
I feel for you.
Old 07-30-2004, 08:32 AM
The bike is always at operating temp, B4 we go enough throttle to get into the pipe. At least 3 or 4 minutes of slow riding. The first time this happened, my kid was riding for at least 20 minutes, then full throttle on straight, melted. Second time was after top end rebuild. Broke it in, by the book. Ran fine. First wide open run, up to 3rd gear. Melted. Went through all the checks and measures, cleaned up the piston, (probably not recommended, buy didn't want to destroy a new piston,just in case). Put bike together, slow riding to check everything out. Screamed it a little. Melted. Bike is completely stock. Jets and all. We bought it used. We rode it 4 months B4 the first melt. Changed nothing.
Old 07-30-2004, 08:37 AM
Mod From Down Under
That seems to point at cooling maybe. Have you checked all radiator hoses for kinks and make sure there are NO blockages.
Also make sure radiator isn't blocked up with grass or foreign debris as this stops air rushing through and cooling coolant and engine.
Old 07-30-2004, 09:12 AM
Water circulation, eveything looks good. warms up pretty fast though. This wouldn't have caused the plug to melt. Has to be an extremely lean condition at full throttle, to melt steel.
I'm baffled!
Old 07-30-2004, 11:43 AM
drman's Avatar
Fender B...reaker!
It might not be the cause, but how is your left side crank seal?
Old 07-30-2004, 11:46 AM
I took the left sidecover off, sprayed starting fluid all around with the motor running. No rpm rise.
Old 07-30-2004, 11:54 AM
cr2504life's Avatar
Last Online: 09-29-2009 04:55 AM
your main jet isn't clogged with something is it??
Old 07-30-2004, 12:26 PM
Had the carb cleaned and jets checked between 2nd and 3rd disaster. All stock jets, checked the numbers. Air screw 1 1/4 turns out. Didn't change jets or any settings, from when we got the bike. Rode it fast and hard for 3 months B4 anything happened. I was actually getting ready to rebuild the top end, when it blew the first time. Figured it was about ready. Guy rebuilt top right B4 we bought it.
Old 07-30-2004, 12:50 PM
stickboy's Avatar
Stickboy (Stik' Boi')
Last Online: 11-13-2007 06:12 PM
get a new bike
Old 07-30-2004, 12:54 PM
Just give me your motor!
Old 07-30-2004, 12:55 PM
stickboy's Avatar
sorry owuld like to but cant i need it till the end of october
Old 07-30-2004, 01:01 PM
Last Online: 07-17-2006 11:38 AM
What kind of piston are you running?
is the cyliner stock?
no porting?
nicksil plating, or has it been sleeved?
WOT it burns,,,,,,it sounds like a mainjet issue,,,,,BUT you say everything is stock. How about the needle and needle jet?
What do you have for exhaust?
let me know
Jeff
Old 07-30-2004, 01:02 PM
stickboy's Avatar
250f
Old 07-30-2004, 01:10 PM
Cylinder is sleeved. The original piston I think was ProX. I put a Wiseco in. Measured ring gap, it was good. By the book.
Other than that it is completely stock. Pipe and everything.
Needle is the same setting as it was when I got it.
Does the needle setting have anything to do with open throttle? I think the needle pulls almost completely out when the slider is up. No?
Old 07-30-2004, 01:11 PM
stickboy's Avatar
ask Vet912 whats up he might now he just did alot of stuff ot his piston on his crf450
Old 07-30-2004, 01:39 PM
YZGreg's Avatar
You can call me ROBOMAN
Last Online: 04-08-2006 12:32 AM
The needle controls 1/4 to 3/4 throttle and usually will be in the middle position on a stocker. If the clip is above the middle slot it will be leaner and the opposite if it's in one of the lower positions. So I would richen it up a bit (by moving the clip into a lower postition). Also how much compression are you running, maybe it was set up for racing and has very high compression which would want to drink race gas. I knew a guy that ran one tank of regular in his pinger and it melted a hole through the top of piston.
P.S. Stickboy, thumpers and pingers are a totaly different beast so I don't think it would be the same problem.
Old 07-30-2004, 01:58 PM
We've never met before :
Old 07-30-2004, 02:15 PM
Do you mean regular as in....no premix oil, or regular octane?
I do use regular octane, But it did have right mixture premix oil.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: THIRD TIME
when is the right time? YZ250-AlexD 4-Stroke Motorcycles - General Discussion 12 10-05-2007 11:45 AM
OT: FUN Time Supermoto General Discussion 24 07-16-2005 12:03 AM
300 Time dixienw123 General Discussion 16 06-23-2005 11:08 PM
vB.Sponsors
