Old 05-23-2011, 01:47 PM
Last Online: 06-25-2012 07:08 AM
Default Taking off forks
Quick question, I have a 2000 yz250 I'm taking the forks up too a shop, how do I take them off then when when I put them back on, how do I adjust the clamps back to factory specs thanks-Jackson.
Old 05-23-2011, 02:05 PM
dodging_roost's Avatar
Last Online: 05-30-2018 06:46 PM
The easiest way to get them off is to elevate the front wheel on a stand.
First remove the tire loosen the pinch bolts first, I always go in a diag pattern you do not need to take them all the way off but you can.
second remove the axle by twisting it counter clockwise until it's free and then pull it out.
next with the front wheel removed pull the brake caliper off should be 2 bolts on the fork leg.
now remove the front number plate and loosen the pinch bolts on the triple clamps there should be 2 upper and 2 lower, you do not have to remove them either just loosen them.
At this point your forks should slide out the bottom of the triple clamps easily.
To install them it is basically the reverse order with a torque wrench to get the bolts to spec on torque.
Thanks
Scott
Old 05-23-2011, 04:39 PM
Dude thanks so much forks are being rebuilt tomorrow I'm prepping for an all weekend ride
Old 05-23-2011, 05:03 PM
bbrmotosports's Avatar
Rockin A class
Sometime is may help to take a chizel or flat head screw driver to lightly spread " with the bolts lose not out" the clamps apart to slide the tubes out.
Similar Threads for: Taking off forks
taking off Cr125guy 2-Stroke Dirt Bike Forums 7 05-18-2010 08:08 PM
Are cr125 forks the same as cr250 forks? Beans 2-Stroke Dirt Bikes - Honda 1 04-13-2009 11:09 PM
taking my yz125 forks apart misfitsbob Dirt Bike Suspension Tuning 14 08-29-2007 07:29 PM
Taking a sig request... Z-Man 393 Photo & Video 4 07-31-2004 11:24 PM
