Old 12-23-2017, 10:21 PM
bjunior's Avatar
novice
Last Online: Today 01:05 PM
Default Stuck bolts in power valve.
ON MY yamaha yz 250- 2013 in the power valve there is 1 allen head bolt and 2 screws that wont budge . I HAVE TRIED A LEFT HANDED BIT AND AN EASY OUT STILL wont budge. There is not alot of room to work in. any help would be fine. keep on 2 wheels. thanks
Old 12-24-2017, 07:13 AM
Big Maico 393's Avatar
Super Moderator
Last Online: 08-07-2020 07:39 PM
Question did you buy this bike new or used?
Maybe someone used RED loctight Which would require heat to break the seal>
Or you can try using some heat from a heat gun & some PB blaster.
Old 12-24-2017, 11:22 AM
wFo250's Avatar
will fall over
Last Online: 05-12-2021 11:54 AM
Start with an impact driver and you won’t need an easy out.
Old 12-24-2017, 06:28 PM
Last Online: 11-17-2021 07:05 PM
None of the screws are left handed. A cordless impact drill/driver works well for removing screws. If you have stripped them out, you will have to try to get them with needle nose vice grips or cut slots for a flat head screwdriver.
Old 12-26-2017, 09:09 PM
wFo250's Avatar
will fall over
Cordless, and battery less impact driver
Old 12-26-2017, 11:08 PM
bjunior's Avatar
novice
i MEANT TO SAY when i said left handed i meant after i mangled the head .I WAS TRYING TO BACK THEM OUT with a left handed drill bit I KNOW they are not left handed threads.
thanks for the imput.
---------- Post added at 09:08 PM ---------- Previous post was at 08:50 PM ----------
Also what is a good vise to hold the cylinder when its removed .
Old 12-27-2017, 07:00 AM
Super Moderator
See if you can get them out with a needle nose vice grips!
Similar Threads for: Stuck bolts in power valve.
250 power valve stuck and no power. kx250_33 2-Stroke Dirt Bikes - Kawasaki 5 10-28-2017 08:40 AM
Stuck Valve Buckets shsfunny 4-Stroke Dirt Bikes - Yamaha 5 08-24-2013 07:37 PM
How to modify the Valve limiting stop stock and power Valve slaurent91 2-Stroke Dirt Bikes - Honda 0 04-30-2012 11:05 PM
exhaust valve/power valve function / problem mjcho 2-Stroke Dirt Bike Forums 3 09-11-2007 08:33 PM
RC Valve shaft stuck! reean 2-Stroke Dirt Bikes - Honda 14 07-19-2007 10:47 AM
