All Things Moto! Web Forums
shopping list for ring job
This is a discussion on shopping list for ring job within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I am going to do the rings on my 04, what do I need aside from rings, gaskets and new ...
Old 07-12-2004, 12:36 PM
Last Online: 02-24-2005 04:47 PM
Default shopping list for ring job
I am going to do the rings on my 04, what do I need aside from rings, gaskets and new circlips? Should I bother honing the cylinder or wait until I do the piston in the winter?
Old 07-12-2004, 12:38 PM
char393's Avatar
Incretacular!!
Last Online: 11-05-2009 09:17 PM
Default Re: shopping list for ring job
Seems to me, if your cylinder is plated, you're not supposed to hone it. Although I could be wrong.
Old 07-14-2004, 10:49 AM
Well I ordered all oem stuff from extreme powersports..
Here's the list
2 of 93450-19052-00 - .CIRCLIP @ $1.34ea.
1 of 5CU-11993-00-00 - .GASKET @ $2.23ea.
1 of 5CU-11603-10-00 - .PISTON RING SET (STD) @ $29.42ea.
1 of 5CU-11354-00-00 - GASKET @ $3.48ea.
1 of 5UP-11351-00-00 - GASKET, CYLINDER @ $18.35ea.
1 of 5XF-13622-00-00 - GASKET, VALVE SEAT @ $2.04ea.
2 of 93210-15639-00 - O-RING @ $0.49ea.
1 of 93210-74316-00 - O-RING @ $3.69ea.
1 of 93211-02703-00 - O-RING @ $4.11ea.
I paid a little more for oem but I don't mind.
Old 07-14-2004, 01:36 PM
Bad Dos's Avatar
Last Online: 07-06-2006 06:05 PM
Make sure that you don't hone your cylinder... It's plated, and if it's damaged it will need to be bored and possibly sleaved.
I normally replace the piston at the same time, to ensure that it doesn't warp.
Old 07-14-2004, 05:45 PM
Blitz393's Avatar
^^Get High^^
Last Online: 10-16-2009 07:12 AM
unless you are replacing the piston, you don't need to change the circlips. the circlips hold the wrist pin inside the piston and on the rod. a ring job should only require coolant, rings, and a topend gasket set- about 50 dollars worth of parts if you buy good coolant. ($15-coolant $12- ring $25- gasket kit)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: shopping list for ring job
Helmet cam shopping weld_13 General Discussion 26 01-27-2009 05:51 PM
Bike shopping! Silver_Fox General Discussion 9 01-24-2007 09:07 AM
My shopping list Rider General Discussion 20 01-21-2006 02:00 PM
standard, o-ring or x-ring KX125 KKXR400R General Discussion 7 06-24-2004 11:32 PM
Did a little shopping Woody_YZF ATV/UTV - Yamaha 16 06-08-2004 11:53 PM
vB.Sponsors
