Shift Fork help!
This is a discussion on Shift Fork help! within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Well after much fun on the YZ 250 I have finally damaged it. When I'm going into fourth it cuts ...
Old 08-01-2004, 06:00 AM
Aussie@Down Under!
Last Online: 01-22-2006 08:02 PM
Default Shift Fork help!
Well after much fun on the YZ 250 I have finally damaged it. When I'm going into fourth it cuts in and out of gear (bugger!) This is the second bike that I have stuffed the shift forks! There must be something in my riding that I,m doing rong! Has anyone else had problems with these bloody things and if so do they no why?
Could be the beach drag races and banging it into gear. Just wondering if I should use less clutch. Always try to slip it when changing but maybe that loads the gearbox up with too much power. Any Ideas?:
Also this is an awesome bike! What a great free reving, powerful motor!
With the pro circuit pipe its the bomb! Instantly on the pipe!
Old 08-01-2004, 06:10 AM
Aus_Rider_22's Avatar
Mod From Down Under
Last Online: 03-14-2010 10:40 PM
Default Re: Shift Fork help!
Those beach races sound awesome!
It is disappointing to see the shift fork blowing out twice. I would check that your clutch is adjusted properly, just as a precaution as shifting under constant load in sand all the time would put extreme stress on the gearbox especially if the clutch is not adjusted right.
Also, I would recommend changing your transoil after every ride being anywhere near water. Good luck and let us know what you find.
Old 08-02-2004, 09:11 AM
Aussie@Down Under!
Thanks Geoff! Hey you gotta come over West and try out the dunes at Lancelin!
The damage has been on 2 bikes I've ridden 426,250
At least I got no worries stripping it down for the repair!
Similar Threads for: Shift Fork help!
TIP - MAKE SHIFT - FORK SEAL DRIVER yamahootin Motorcycle Suspension Tuning 3 04-29-2009 10:46 AM
RM 250 shift fork acw592 2-Stroke Motorcycles - Suzuki 7 11-17-2007 09:13 PM
down shift and up shift without clutch????? busaturbo15 General Discussion 11 09-12-2007 11:12 AM
Shift fork problems... Spitfire General Discussion 0 05-13-2005 05:05 PM
bad shift fork and pinion gears??? Boostn 4-Stroke Motorcycles - Yamaha 0 03-07-2004 09:09 PM
