running too rich do I move the clip down or upThis is a discussion on running too rich do I move the clip down or up within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I pulled my plug on my yz125 today and it was all black and oily..should I move the clip up ... |
| I pulled my plug on my yz125 today and it was all black and oily..should I move the clip up or down on the needle jet? |
| To make it leaner, you move the clip downwards. |
| ifn you move clip down it will lift the placement of the needle letting more fuel in (richer)if you move up it will drop needle farther into main jet letting less fuel in (leaner) but thid only controls closed throttle to 1/4 trottle you sould look into main jet change |
| The clip only affects the richness of the mixture from 1/4 to 3/4 throttle,, is it rich there or under 1/4 throttle or at full throttle.. first you need to make sure you have the right main jet size.. warm up the bike, put in a new plug, go wide open (WOT) through 3 gears, hold the kill switch while staying wide open, and take the plug out and check before you start the bike again. If it is rich there then you need a smaller main jet.. If not you can try another new plug and ride around keeping it around half throttle,, that will tell you if the clip needs to be moved.. check out this [Only registered and activated users can see links. ] |
| I dont know my bike just takes a bunch of kicks to start and when I put a new plug in it starts 1st kick so i know its the jetting...its annoying, I went to take the carb off but its impossible to take it off without taking off 5 other things so I didnt feel like doing it now. All I know is that its hard to start and has a oily black plug! |
| It might be time for a new top-end. Blow-by maybe ocurring. |
| Running rich.. | Shoei_391 | General Discussion | 8 | 05-17-2007 09:59 PM |
| Running RIch | Dirtmanabe | 2-Stroke Motorcycles - Yamaha | 10 | 10-28-2004 08:16 AM |
| Running to Rich? | Bryce | 2-Stroke Motorcycles - Honda | 14 | 03-12-2004 04:06 PM |
| Running rich? | Jason | 4-Stroke Motorcycles - Honda | 18 | 10-22-2003 09:50 AM |
| running rich | VET393 | 4-Stroke Motorcycles - General Discussion | 8 | 10-06-2003 06:42 AM |
