powervalveThis is a discussion on powervalve within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; when i went to check my power valve on my 02 yz 125 i took off my fatty and when ... |
| when i went to check my power valve on my 02 yz 125 i took off my fatty and when i looked up there all i saw was my exhaust port and piston and no power valve... is there something I'm not doing right? i think the linkage has probably come undone but i see no powervalve where i am supposed to ? |
| I see you have been hit by that band of internationally known power valve thieves. Try taking the linkage cover off (it is on the righthand side of the cylinder) and see if they took the linkage too. You may want to lift the front cover and look for the shaft and springs that control the valves' movement. They may have gotten those too. If so you are going to be spending a lot of money. |
| i now see that one of my powervalve linkages has come off and i have to take off my entirer cylender to get that cover off to reattach it |
| the 01 cylinder on mine will let you do about anything with the valves and linkage with the cylinder on from what I can tell. It is easier though to have it on a bench. How was it running? |
| the bike was running good pinned but when i acelerated it really sucked as it would sorta bog and i knew it wasdnt the jetting so i took offf my pipe and sure enough one of the powervalves were limp. so the only way to reattach it is to remove the cylender because the powervalve cover is like a 1/2 inch from the frame soo off comes the cylender. do i have to replace the base gasket or will it be fine i think im gunna do it anyways but im just wondering? |
| now that ive got it off and i realize that one of the little linkage rods came undone i was wondering, is the ypvs supposed to be full of oil? i am draining it to work on it but i was wondering if i do should i replace that oil? or is it tranny oil that came up my linkage? |
| YZ 125 Powervalve Q.. | Kidafa | 2-Stroke Motorcycles - Yamaha | 3 | 11-06-2008 08:29 AM |
| wr 250 powervalve | rotorfly | 2-Stroke Motorcycles - Yamaha | 0 | 02-17-2008 08:57 AM |
| Yz 125 Powervalve ? | ktm125man | 2-Stroke Motorcycles - Yamaha | 1 | 11-11-2007 09:38 PM |
| 01 CR 250 Powervalve | Dirt Surfer | 2-Stroke Motorcycles - Honda | 0 | 03-23-2005 08:53 PM |
| powervalve WILL NOT come out! | Blitz393 | 2-Stroke Motorcycles - Yamaha | 11 | 07-14-2004 12:25 AM |
