plug nut dripping? yz250 2002
This is a discussion on plug nut dripping? yz250 2002 within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; i recently rethreaded my plug nut on my yz250 2002 and it was fine for a few days but nows ...
Old 12-01-2006, 11:56 PM
yz250braaaap's Avatar
Last Online: 07-28-2007 11:16 AM
Default plug nut dripping? yz250 2002
i recently rethreaded my plug nut on my yz250 2002 and it was fine for a few days but nows it dripping. i took the oil out and put another rubber washer on and she still leaks, i sort of made a washer out of pipe tape because its supposed to stop leaks and i donno if its gunna work. i would show u a pic but i dont know if u can see this image. if u can see this let me know and ill take a pic of my problem if itll help but in the meantime, any advice?
Old 12-02-2006, 06:23 AM
pragmatic393's Avatar
..Thats, Mr. Spode to you!
Last Online: 02-24-2010 10:00 AM
Default Re: plug nut dripping? yz250 2002
Do a search on "Oil Drain Stripped" Mucho info on this, One that Keetoman referenced is ~[Only registered and activated users can see links. ]
Keetoman is one of the best strippers on ATM
Old 12-02-2006, 07:42 AM
RMZracer212's Avatar
Thumpin it up!!!
Last Online: 09-28-2009 10:01 PM
Keetobunny is his stripper name!!
Old 12-02-2006, 09:08 AM
boogieonmyfinger's Avatar
Last Online: 03-11-2009 02:26 PM
Featuring nuts that don't leak.
Old 12-02-2006, 09:22 AM
lmao ty, but its not stripped. its just dripping
Old 12-02-2006, 10:36 AM
MotoMan's Avatar
Floppy
Last Online: Today 02:23 PM
I had this same issue when I re-threaded the drain plug on Jaces 50. A rubber o-ring type wouldnt stop it either, so I went to the hardware store and bought a neopreane type washer, not really neoprene but something that would seal against the case and swell/conform to the whole surface area. No more leaky.
Old 12-03-2006, 06:50 AM
h8-2-w8's Avatar
I assume since you tapped the case to a larger size you did puchase a new bolt with a head flange that was the equivelent of the oem bolt. The flange ensures a sealing surface between the case and bolt head. This is imperative to ensure your best chances of a drip free seal. You may have created an irregularity in the mating area of the case from your retapping procedure. Check the deck of the case surface. If you determine a variance in the surface you may be able to clean it up or you could use an appropriate sized cush washer (similar to a washer on your sparkplug) to provide a sealing surface. You have purchased a bike that requires a great amount of maintenance. I wish you well with your limited mechanical ability. If anything the bike will provide a proving ground for you mechanical skills. Can't wait to hear from you with a siezed crank! PS>>>You don't use a rubber o- ring on this bolt ever! unless you want the bolt to fall out in the woods while your riding it...
Old 12-03-2006, 07:57 PM
lmao, this kid has no idea whaaat the heck hes talkin about, the stock yz250 plug nuts comes with a rubber washer (o-ring). by the way, i have stopped the leaky leaky. the plug nut wont fall out in the woods because i ride on a track and practice for races... another thing, what would make the nut fall out by just being about 1mm out a little farther. like its made to do. just to think about: I am probly more mechanicly inclined then you by far. dont even argue, you have no idea. if my crank seized i would pay 100$ for a new one and put it in myself... intelligence is a factor mr 5 posts
Old 12-03-2006, 08:13 PM
YZ125motoracer's Avatar
125 Novice
Last Online: 09-24-2009 11:57 PM
intelligents is a factor mr 5 posts
LMAO
Old 12-03-2006, 08:20 PM
lmao myself. im tired, its 10:30 i gutta get up 4 work
Similar Threads for: plug nut dripping? yz250 2002
2006 YZ250 plug reading twan121 2-Stroke Motorcycles - Yamaha 20 02-27-2007 10:17 AM
2002 CR 125 Spark Plug Question bookoochad422 2-Stroke Motorcycles - Honda 1 02-13-2007 07:42 PM
yz250 2002 leaking around plug yz250braaaap 2-Stroke Motorcycles - Yamaha 17 11-27-2006 06:16 AM
yz250 2002 plug bolt and oil pan stripped!!!! yz250braaaap 2-Stroke Motorcycles - Yamaha 11 11-24-2006 11:35 AM
2002 YZ125 spark plug Dist34_678 2-Stroke Motorcycles - Yamaha 8 07-01-2005 08:05 PM
