All Things Moto! Web Forums
No spark on yz 125
This is a discussion on No spark on yz 125 within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Ive got an 89 yz 125 that im tryin to fix up. It isnt getting any spark, ive replaced the ...
Old 09-07-2004, 07:04 PM
kevinfries's Avatar
Last Online: 12-24-2004 10:28 AM
Default No spark on yz 125
Ive got an 89 yz 125 that im tryin to fix up. It isnt getting any spark, ive replaced the cdi and parts of the stator, and spark plug. I cant figure out why it wont get any spark. Got any suggestions? Tomorrow i am going to trace all the electrical lines to check for splices or tears. Any suggestions? Thanks
Old 09-07-2004, 07:29 PM
OlSchoolFool393's Avatar
Older than DIRT
Last Online: 10-03-2009 11:30 AM
Default Re: No spark on yz 125
Check Grounds if you did any painting
Old 09-07-2004, 07:38 PM
kevinfries's Avatar
where would i check the grounds?
Old 09-08-2004, 05:05 AM
klp klp is offline
Last Online: 01-24-2005 05:08 PM
Hey if u read my therad we are in the same boat. Follow all the wires to where connect to the frame or motor then verify they are a good ground with a tester, very cheap at Sears if u don't have one. U may want to test your cioil too.
KP
Old 09-08-2004, 05:20 AM
kevinfries's Avatar
i forgot to mention i also replaced the coil, i will try the grounds later, thanks.
Old 09-08-2004, 05:21 PM
kevinfries's Avatar
if the kill switch was not hooked up, like the wires werent connected for it, would that cause an incomplete circuit or something so no spark?
Old 09-10-2004, 02:20 PM
kevinfries's Avatar
i took the rotor off and was looking at the stator, it seems like it might be missing a wire, but i dont know. Also where do i connect the kill switch to? I know where one wire goes, to the ignition box, but i dont know about the other. Here are some pics to help you understand more.
Old 09-11-2004, 06:55 AM
klp klp is offline
I don't know much about stators but your kill switch needs one wire to the black box and one to ground. That could be either a common ground or simply ground it on the handlebar. Hope this helps.
KP
Old 09-11-2004, 08:18 AM
kevinfries's Avatar
Ok thanks
Old 09-11-2004, 09:19 AM
kevinfries's Avatar
Ok i found out one of the things wasnt grounded(i cant remember names this early in the morning) so i did some grinding got all the paint off, and grounded the kill switch with it. Still doesnt work. Can you have two grounds on one piece of metal? If so, any other suggestions on what to check, thanks!
Similar Threads for: No spark on yz 125
'02 CR 125 No Spark TooTer 2-Stroke Motorcycles - Honda 4 04-18-2009 03:09 AM
cr 80 no spark atc250r 2-Stroke Motorcycles - Honda 1 04-16-2009 10:06 AM
No Spark! BladeUK2001 2-Stroke Motorcycles - General Discussion 1 05-09-2008 09:20 PM
YZ 250, no spark soccer2963 2-Stroke Motorcycles - Yamaha 1 07-19-2005 06:36 PM
No spark on yz 125 kevinfries 2-Stroke Motorcycles - General Discussion 1 09-07-2004 10:18 PM
