Old 06-29-2014, 10:07 PM
Last Online: 09-16-2014 12:18 PM
Default New to the yz490 looking for help
So I just got a 1982 yz490 starts awesome runs awesome but forks are soft and massively leaking oil so I was woundering if the seals are hard to replace and if I should get stiffer springs? Also a good rear spring is in order I think as it is quite soft aswell, Any thoughts as to a good spring/fork kit? I'm 6' 150lbs. Skiny for a bike this size but it was to good to pass up
Thanks for any info.
Old 06-30-2014, 07:13 AM
arnego2's Avatar
Leaking forkseals are often just dirty, a plastic or firm carton strip running between fork leg and seal cleans dirt off pretty good.
Old 06-30-2014, 09:20 AM
Randog Leader's Avatar
If it is a small leak, probably. But based on the age of the bike and the word "massive", I would tear them down and replace the seals if I were you. Soft could be from all the lost oil in the forks but then again, the springs may be sacked out from the age of the bike. Measure the free length of the springs while you have the forks apart and compare to spec.
---------- Post added at 09:20 AM ---------- Previous post was at 09:18 AM ----------
Also, be sure to run your fingers along the fork tubes and check for any burrs that may be causing the leak. Small ones can be buffed away but large ones indicate new fork tubes in your future.
Old 06-30-2014, 01:03 PM
TRexRacing's Avatar
I have an '82 490 front end on my '80 YZ465. It has a set of RaceTech cartridge emulators and triple rate springs set up to RaceTech's specs. Huge improvement I highly recommend to anyone who's going to ride a vintage YZ.
Old 06-30-2014, 10:53 PM
That sounds nice, I was kinda thinkings bout that set up. If you don't mind saying how much we're they? Also I have valve stems at the top of my shocks, is that factory and if so what pressure would I run?
Old 07-01-2014, 06:06 AM
TRexRacing's Avatar
Less than $300 in parts. I run zero pressure,just use 'em for pressure release.
Old 07-01-2014, 09:26 AM
That's not to bad at all! Thanks
Similar Threads for: New to the yz490 looking for help
YZ490 Yamyman 2-Stroke Dirt Bikes - Yamaha 7 06-04-2011 01:58 PM
YZ490 help blazef20 2-Stroke Dirt Bikes - Yamaha 19 01-15-2011 08:28 AM
87 YZ490 chrisman 2-Stroke Dirt Bikes - Yamaha 6 01-31-2010 10:33 AM
My yz490 jackdim 2-Stroke Dirt Bikes - Yamaha 30 07-31-2009 05:23 PM
79 yz490 yz490oc714 2-Stroke Dirt Bikes - Yamaha 23 07-02-2007 04:29 PM
