New Rider/Old Bike
This is a discussion on New Rider/Old Bike within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I would look at the actuator arm for wallowing out on its mounting hole, or the actuator shaft being worn ...
Old 03-21-2003, 10:59 PM
Semper Fidelis
Check the actuator arm
I would look at the actuator arm for wallowing out on its mounting hole, or the actuator shaft being worn where the arm mounts. the cable can stretch a fair amount but 3/8" is a lot (not unheard of though.)
I would pull the clutch basket and look at the shaft and seal since you are there but they will not have anything to do with the cable free play. Since the bike has a few years on it checking the seal and crank end will be a good thing to inspect while you are in there.
Let me know what you find and if the new clutch cable does the trick.
Bill
Old 03-22-2003, 07:16 PM
Last Online: 09-06-2003 06:33 AM
Default Re: New Rider/Old Bike
The new Yamaha cable was about 3/4" shorter, and much better construction and thicker cable than what was on there. The dealer recommended I rough up the clutch steels a bit w/scotchbrite or emery cloth before reinstalling. Is this a good idea?? I can think of pros and cons for this.
BTW, the springs, steels and friction discs are within spec for thickness, and the actuator arm and hole looked OK.
Will pull the clutch basket tomorrow AM then put it back together.
Thanks!
Eric
Old 03-22-2003, 07:24 PM
Semper Fidelis
Clutch cable woes
I think you licked the problem with the new cable. As to roughing up the steel plates, I have not done this or heard of it before.I would hate to recommend something I am not ffamiliar with. You should get Eric Gorr's book on performance tuning and maintenance for dirt bikes. it is invaluable for doing your own work. John and I have it, ad do many members here and throught out the dirt bike community. It answers a multitude of questions for the do-it yourselfer.
Bill
Old 03-23-2003, 07:18 AM
Thanks for the Eric Gorr tip! On his website it answered my oil fill concern. He said "The reason for the great discrepancy in the oil volume, is that the oil runs directly from the filler hole to the level hole. The oil flows along the inside of the clutch cover and out the level hole. The level hole is designed for quick level checking. Also the oil backs up in the clutch cover before it fills the tranny. Its best to wait about twenty minutes before you try to check the oil level. I just fill the tranny with the prescribed measured volume". That tip might have saved me a ton of money right there had I underfilled it by just calling it quits after the oil came out the plug.
Am going to order his book, and will be riding again soon.
Thanks!!!
Eric
Old 03-23-2003, 07:51 AM
Semper Fidelis
Talking Eric Gorr
Book mark the site and buy the book. I got one a year ago and it is a really handy reference. Combined with my owners manual from Yamaha it can lick most any problem. Tryce highly recommendd Eric's site and book to me and that is about all I need to trust something and I am really picky about our bikes. (Engineer's Disease )
Bill
Old 04-13-2003, 04:42 PM
4strkepwr660R's Avatar
Eat, Sleep, and Ride!
Last Online: 12-18-2008 02:20 PM
Originally posted by Blitz393
if it won't idle while warm, then join the club. the ONLY two-strokes that i have seen idle is the banshee and blaster, but the blaster kept on trying to die on me when i traded the guy for a while. mine still needs adjusting, but i can't even leave it alone long enough to buckle my helmet, i have to have it on when i start it. then i give it a handful of gas and while it is throttling down, i snap on my goggles. the off-idle might be a clogged Pilot jet, or even the gas might have turned to Varnish, if left for a REALLY long time.
now, can't you see why we are so addicted?
does it still have the pink seat in '95? or did they change to blue yet? i can't remember, but mine was pink and white when i got it, but since then i have invested in a black CEET gripper seat cover.
-Rob
Rob, I got my LT to idle If you dont believe me you can come to my house and see it if you want too
Old 04-13-2003, 07:30 PM
Blitz393's Avatar
^^Get High^^
Last Online: 10-16-2009 07:12 AM
sure, i wanna ride the tracks you, joe, and i think rocky?? are building there!
-Rob
Old 04-13-2003, 08:04 PM
Rockey's Avatar
Don't you mean "Rockey got my LT to idle"?
Old 04-13-2003, 09:20 PM
So Rockey, can you offer any tips on getting my YZ250 to idle?
Old 04-14-2003, 01:30 PM
Dell30rb's Avatar
Why, Turn it up of course!
That and a correct air screw setting will let your bike idle. I have mine set so that it idles for about 10 seconds and then dies. I think this is about the correct setting for an mx bike.
For a woods bike (or an mx bike that is used for woods) you might want to try to get it to idle for about 20 seconds. I dont know why, but it seems a slightly higher idle would be best for trail use.
Old 04-14-2003, 03:11 PM
How come i all the sudden get dropped out of this and nobody thinks I have any knowledge! THE WORLD IS AGAINST ME!!!!
LOL
Old 04-14-2003, 04:47 PM
Rockey's Avatar
Of course!
On your bike, I think the idle control is located on the choke knob. Try turning the choke counterclockwise I think (may be clockwise) until the bike will idle.
Old 04-14-2003, 04:48 PM
Rockey's Avatar
LOL
BECAUSE YOU DIDNT GET YOUR LT TO IDLE! :
Old 04-14-2003, 06:05 PM
Yes I did Mike- You had it idling too high and I had to lower the idle...Kiss my @$$!!!! LOL...No harm taken
Old 04-14-2003, 06:17 PM
Rockey's Avatar
Old 04-14-2003, 07:46 PM
Default Idle - or lack thereof
It seems turning the idle screw/choke knob doesn't make any difference, but yes it is moving as it should. I haven't tried the air screw yet, I set it to the factory setting of 1-1/4.
Old 04-14-2003, 09:15 PM
Semper Fidelis
Talking 2-stroke idle
Y'all need to keep in mind that the new 2-sroke MX bikes with the current carbs and ignitions are not really prone to being able to idle if jetted properly for running in the meat of the power band. That is the nature of the beast. They can be made to idle but that is not how they are ported or jetted. The EXC model KTM's and the WR Husqvarnas and the Gas-Gas 2-strokes are the exceptions. However they are not top end runners. the laat of the 500 class pingers like Madman's KX 500 are an exception to the non idle rule. that is one reason I wish the manufacturers would make true 2 stroke open class dirt bikes again. I love 'em !
Bill
Old 04-18-2003, 07:28 AM
Rockey's Avatar
Bill, you would LOOOOOOOOOOOOOOOOVE the CR500AF from service Honda! And if you don't you can always send it to me!
Similar Threads for: New Rider/Old Bike
New rider! what bike? turbo94gt What Motorcycle or ATV 10 04-06-2009 09:02 AM
What bike for a new rider? jker What Motorcycle or ATV 18 08-18-2007 09:18 AM
New bike for an old rider DavidBeebe Member Introductions 4 08-05-2007 09:28 PM
Bike for a new rider. Synyster06Gates What Motorcycle or ATV 48 06-15-2007 05:47 PM
old street rider, new dirt rider, what bike? newdirt General Discussion 7 01-06-2004 12:51 AM
