need help for a 03 yz250This is a discussion on need help for a 03 yz250 within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; ok i need to know if there is oil pull plug so all the oil comes out?? but i have ... |
| ok i need to know if there is oil pull plug so all the oil comes out?? but i have notice sum oil comes out of my hose so i dont know if it is the oil from the tran?? so i need help =/ |
| Do you have a pic of were this hose and leak is comming from? or a little bit more of a description of were the leak is at? |
| The oil drain is located at the bottom of your engine. The oil coming out of the hose is the powervalve breather. Hope this helps. |
| Yes, 14mm bolt on the bottom of the transmission is the oil drain bolt. Re torque it to 14 lb ft and refill with 750ml (I use a cheap Wal Mart plastic measuring cup) of oil. The oil your seeing is more than likely from the power valve blubber tube, mine drools a few drops on the truck bed floor on the way home from a ride once in a while. This is normal. |
| The splooge from the power valve breather is usually black, like ink. It seems to get everywhere like ink, too. I hope your tranny oil isn't that black! Scott |
| YZ250 FS | AceYZ250 | Motorcycles & ATV's | 3 | 10-22-2007 07:06 PM |
| yz250? | talnteddriver29 | 2-Stroke Motorcycles - Yamaha | 7 | 08-20-2007 01:32 PM |
| 04 yz250 top end | bush ranger | 2-Stroke Motorcycles - Yamaha | 3 | 08-30-2005 01:42 PM |
| 01 yz250 | spdfrek | Motorcycles & ATV's | 6 | 05-12-2004 08:57 AM |
| new yz250 | avandesande | 2-Stroke Motorcycles - Yamaha | 4 | 01-26-2004 08:03 AM |
