need adviceThis is a discussion on need advice within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Ok heres the deal i just bought a 01 yz250 that had only been riden 6 times from a buddy ... |
| Ok heres the deal i just bought a 01 yz250 that had only been riden 6 times from a buddy of mine he put v-force reed valve fmf pipe and race tech suspension i got bike for 2000$ not bad deal huh but heres the prob i wanted a 2002 yz250 the 02 has the modified ypvs power valve that makes the throttle response crisper across the entire RPM range where as my 01 is just a beast on top end anyone have any ideas how i can make it more like the 02 can i mod my power valve? i know its probly a lost cause but hell its worth a shot |
| That sounds like a pretty good deal. If your riding tracks mostly and not open desert, I would gear it lower by adding a tooth on the rear sprocket. Maybe even throw some new knobs on the rear to better suit your riding conditions. |
| You may want to check into the Power Now gadget. I really dont know if they work that well or for the low end response, but its worth a look. |
| I think your 2001 YZ250 with the V-force reeds and FMF would be faster and more responsive than the stock 2002 YZ250! So I wouldn't worry about having a inferior model when yours would probably easily match the newer bike. |
| I'm with aus rider. There can't be that big of a difference. |
| Have you actually ridden a 2001 and a 2002 two at about the same time?? I have and could tell little difference. Just throw the magazines away and enjoy. If that wont work by a 2002 cylinder. |
| I already got a larger rear sprocket and he had put new tires on it im in Ky so no desert here im a track rider hell have a 6 acre track in my back yard and yea i have rode a 02 and my 01 on same day my brother has a 02 it also has the v-force reed valve the bike just feels more controlable but its not a big deal i was just curious if there was some way to mod the power valve or maby put a 02s power valve in my 01 but like someone said its not that noticable hell most people probly couldnt feel a differance as long as i can still smoke his *** at the track im fine but thanks for the replys |
| The 01 is a better bike in my opinion. In 02 the frame was stiffer and the suspension as a result felt stiffer. I put an 11oz flywheel on mine. a gnarly pipe, v forse reeds, stock gearing. That in itself makes for a strong range of power. I picked up on ebay an FMF OTF ignition with the boost/torque switch. It's like having two pipes. I prefer the torque setting everywhere except sand and loam. It's one of my favorite bikes for mx and woods! |
| FMF OTF ignition with the boost/torque switch never heard of it but im interested im gonna look into it more i ride my 01 the more i like it well thanks for the advice and if anyone is ever in ky send me a message i have a 6 acre track in mback yard and im at podeum 1 over in indiana every weekend thanks guys later |
| your lucky that you got that deal..dam thats cheap!!! |
| the power valves are different the 02 was even advertised as having a redesigned power valve "Newly reshaped YPVS power valve system features an all-new valve end collar and extra plate added to the back of the torsion spring, delivering improved airtight sealing for crisper low-end performance" here is a diagram from yamaha of troy [Only registered and activated users can see links. ] [Only registered and activated users can see links. ] also just for hell of it here are all changes to engine made in 2002 but like another guy said its not that noticable i still smoke 90% of the people at my local trackes ALL-NEW FOR 2002 Engine: * Liquid-cooled, 249cc, reed valve-inducted, 2-stroke engine is lightweight, compact and boasts numerous modifications and upgrades to boost its powerband. * Newly reshaped YPVS power valve system features an all-new valve end collar and extra plate added to the back of the torsion spring, delivering improved airtight sealing for crisper low-end performance. * All-new carbon fiber reed-valve petals improve throttle response and engine performance across the entire RPM range. * All-new piston is stronger for improved performance with greater durability. * New-design primary kickstarter features a reshaped crank and smaller-diameter shaft for smoother, easier starting action and reduced weight. * New-design, large-capacity radiator features a 10-row core (up from 9 rows) with 4 louvers (up from 3) to deliver maximum cooling efficiency at all performance levels. * All-new exhaust pipe with redesigned silencer features a reshaped tapered section for broader power delivery with stronger low-end hit for maximum corner-exiting muscle. * Redesigned airbox features improved sealing for more efficient breathing and greater performance. * 38mm Keihin PWK carburetor with power jet and throttle position sensor (TPS) ensures precise fuel/air mixing and extra-crisp throttle response throughout the powerband. * Digital CD ignition system delivers precise spark and monitors engine speed to ensure optimal timing for faster, stronger response during hard acceleration. * Smooth-shifting, 5-speed, close-ratio transmission with heavy-duty, multi-plate clutch. * Trick, works-style clutch lever features race-spec barrel adjuster for on-the-fly adjustability. |
| LOL,,all measured at the brochure!! |
| all measured at the brochure? i have both bikes sittin in my garage along with a 2000 cr250 "for sale" $2100 and my newly acquired 04 crf450 i posted the specs to prove a point i can understand someone not seeing a differnce in 1999-2001 but i could tell a huge diffenance in 2002 maby its just me i ride many diffenant bikes almost everyday and i notice the small things but like i said before ITS NOT A BIG DEAL i was just curious if anyone knew if the power valves could be swapped but i have done tore both bikes down and discoverd NO not possible and i have seen up close the differance my 01 is the better trail-woods bike in my opinion but i think id rather have the 02 on the track, welp time for a new arguement my new crf450 is worst woods bike ever anyone wanna argue that point? |
| What is the problem with the CRF? Too much of a tank? The 02 YZ did gain some extra HP, and also gained some extra flywheel wt. The flywheel gives it the feel of having more torque. |
| The CRF is the worst woods bike ever? I could fix it for ya... I'd even take it off your hands cheap |
#18
| i dunno im still tryin it out so far it just gets to damn hot im all new to the 4 stroke world so give me a few days in the woods but on the track i like it alot took a while to get use to it though so before i start *****in i better give it more of a chance oh and got 2 bikes for sale now the 2002 yz250 he is askin 3200$ and i have a 2000 cr250 for 2000$ i have pics of both bikes and all the junk done to them |
#19
| Is that your private track? |
#20
| yea but its nothin huge we have alot of kids that come out and ride we also own a small track in leitchfield Ky called blackrock but theres nothin like having a practice track in your back yard to fool around on |
| Could use some advice | Duran676 | General Discussion | 13 | 05-02-2009 09:24 PM |
| Hey, need advice plz? | highspeeddirt77 | Member Introductions | 4 | 03-11-2009 04:30 PM |
| Need advice...top end on 95 CR 250 | brn agn | 2-Stroke Motorcycles - Honda | 2 | 02-01-2005 06:03 PM |
| need advice | CR Chick | General Discussion | 22 | 04-06-2004 07:38 PM |
| NEED ADVICE | Buzzencuzzin | 4-Stroke Motorcycles - General Discussion | 7 | 02-16-2004 05:00 PM |
