kick starter not returningThis is a discussion on kick starter not returning within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; hi, my kick starter is not returning on my yz125 2001, ive replaced the torsion spring and still it wont ... |
| hi, my kick starter is not returning on my yz125 2001, ive replaced the torsion spring and still it wont return. thanks |
| oh crap i have the same problem. i just bought the spring. i hope that was my problem. btw how long did it take you to replace the spring. this will be the first real work im gonna do on my 2000 yz125. any tips? maybe a quick step by step for me, |
| It's not hard. Study the arrangement - you will be able to figure it out. I would do a step by step for ya but I would have to have the bike in front of me. Scott |
| yeah its not that hard hey. iam thinking i might pull mine apart again and see whats going on. i hope i can get it to return this time. |
| Sorry for the short reply last time - I suddenly got needed. ...hate it when that happens. I would trouble shoot by inserting the output shaft through the main clutch housing to make sure it rotates freely. Then check to make sure you have all of the location dowels in place to ensure the cover stays aligned accurately - the bolts alone will not do it. There are two location dowels on the case cover. The dowels are cheap if one is lost. If the shaft rotates freely in the cover, then evaluate the mechanism carefully - the return spring arrangement is quite simple. It should require a bit of effort to enage into it's correct location. If it simply falls in, there is something wrong - either the opposite end has broken off or has fallen out of the shaft, the spring is broken or you are trying to install it in the wrong orientation. There is a large tab that limits the return of the shaft and this tab should be resting inside a small depression in the case. There is a plastic insert shell between the spring and the shaft - this keeps the spring engaged into the shaft by limiting the amount of slop between the spring and the shaft. If this is missing or broken or whatever, this could cause the end of the spring to become disengaged from the shaft. This problem might not be too evident on first inspection. The spring clip thingy on the gear is not part of the return mechanism. I have never seen any of these issues (except the missing location dowels). I am simply trying to think of any potential problem that is likely to occur. Scott |
| thanks for the info, now that i think about it, it was quite easy to put back in. it just does not feel like the spring has a load on it. i will hopefully pull it apart this weekend and have a look. cheers |
| Installing Kick Starter Video | Old Man | ATV/UTV - Yamaha | 9 | 10-05-2005 02:08 AM |
| Kick starter | Randy11023 | General Discussion | 6 | 04-25-2005 11:17 AM |
| need help/kick starter siezed | bansheeridder | 2-Stroke Motorcycles - Yamaha | 5 | 07-14-2004 01:34 PM |
| kick starter on 400ex | Newf_Rider | ATV/UTV - Honda | 6 | 03-28-2004 03:26 PM |
| Kick Starter | RaceyCRF250 | 4-Stroke Motorcycles - Yamaha | 2 | 01-15-2004 08:37 AM |
