Just installed the ICAT
This is a discussion on Just installed the ICAT within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Oh man... I think I've just been dooped...
Old 03-16-2006, 07:13 PM
I've been RM-Zedded
Last Online: Yesterday 01:39 PM
Default Re: Just installed the ICAT
Old 03-18-2006, 10:50 PM
Woody_YZF's Avatar
ATM Store Mgr & ATV Mod
Last Online: Yesterday 01:44 PM
Next chance I get I'm going to pull my Icat off and see if I notice any difference. If I can't tell a difference, then I think I'll Ebay it off to someone who doesn't know any better. It came with the bike, so I have nothing to lose either way. I'll let you know my results.
Old 03-23-2006, 09:54 PM
mtk's Avatar
mtk mtk is offline
Mr. Titanium Implant
Originally Posted by Coopsvintageyz
It is very interesting that the ICAT did show a hp gain on top end, when this device should do nothing at all?
It is also interesting that it lost low end?
Dyno's seem to be pretty good proof?
I can make a dyno read whatever I want, with just a slight change of correction factors, and then format my printout so that it doesn't show on the readings.
In addition, you can take five pulls on the same bike and get five different readings, due to both measurement error and also due to variations in engine temperature. A gentlemen I know worked at Factory Pro Tuning for several years and he would use a RayTek IR thermometer on the radiators and engine cases to make sure the temperature of the engine was EXACTLY the same between runs. Anything less and you get different readings.
So the ICAT data can be explained this simply: the first pull was done at less than optimum temperatures compared to the second pull.
Old 03-23-2006, 10:47 PM
FFRacing11x's Avatar
The "ONLY" FastForward
Mike, are you speaking from personal experience or from what your dyno friends are telling you? Just wondering. Tdub
Old 03-24-2006, 07:25 AM
crazyrydermx's Avatar
Don't abbrev.
Last Online: 08-28-2006 04:36 PM
1: I think mtk is on to something. No, temperature changes of a few degrees won't have a drastic change on a dyno. At the same time, it could change it enough to show a tiny small microscopic change on the dyno, as shown on the higher range of rpm.
2: I think I would rather have a device that doesn't lose that much power in one part of the powerband than have one that gains a non-noticeable amount somewhere else.
3: Yep, dynos are the BEST proof.
Old 03-24-2006, 07:41 AM
Vintage Dave393's Avatar
ATM History Professor
But they sure are hard to corner.:
Old 03-25-2006, 12:30 AM
mtk's Avatar
mtk mtk is offline
Both.
The gentleman who worked at Factory Pro Tuning was nice enough to give me some excellent pointers and I did a decent amount of tuning on my roadrace bike on a rented Dynojet dyno. In fact, I'd venture to say that I knew more about that dyno than the manager of the shop that owned it. I can say that because I had to help him set up several items on it. His specialty was making pretty graphs for Harley owners. A friend of mine also has a Dynojet of his own (yes, his garage is a VERY popular place).
Old 03-25-2006, 02:00 PM
One of my first experiences with a dyno involved a "Dyno Tuned" Camaro. It was current pretty much,,, a 68. It came back with my always whining brotherinlaw whining even louder than normal. Seems that after talking to the man who did the tuning (" I just did what that sidewalk expert kept asking for". I so vividly recall his exact words.) You can tune for a peek hp without regard to driveability, just like you can without a dyno.
It seems popular now in testing to use vacuum/pressure on the vent lines to either richen or lean out the mix when testing a product. Way easier than flipping over 1-6 carburetors. Sometimes the jetting that makes the biggest peak numbers is not what you want to ride. That practice now will allow a dyno operator to get the engine into a certain rpm band,,then tune it while it is there jettingwise. Handy, but you can see how if the process stops there it may not be ready for the street, or track. The real operators know this and use it in it's proper intent.
Kind of like what my brotherinlaw asked for. I am not sure he ever learned to be careful of what he asked for.
My first experience of actually using one was a shop dyno for diesel engines. It was there to make sure that the engine left with the rings basically seated, crankcase pressure was within limits, and that the engine was putting out within the margins. No tuning was done in this case. All it really was was a water pump. You could see what kind of volume and pressure you could achieve and calculate torque and hp with reasonable accuracy.
Old 04-12-2006, 08:52 AM
paul reed's Avatar
pro class pimp
Last Online: 05-19-2009 07:59 PM
ok,who needs a frigin DYNO anyways...the old school time tested seat of the pants method works best,and it actually seemed to make my 1973 toyota truck climb hills better with a simular device as the iCAT-i`ve spent twenty bucks on some pretty stupid stuff but i still do feel that this particular device helps as i`ve seen it demonstrated by someone who had sold them for over 7 years in the same spot at the local swapmeet and like he said...have you ever seen anybody standing around complaining? i have seen his demonstration many times -i have never tried or used an i CAT,but i just had to chime in here
Old 04-12-2006, 08:57 PM
Crazy's Avatar
Accident Prone
Last Online: 10-25-2009 10:00 AM
The pinging in your truck could also have been fixed for free by retarding the timing a few degrees.
Old 04-25-2006, 07:10 PM
mtk's Avatar
mtk mtk is offline
You can "feel" all you want, but the I-CAT is still a fraud.
Old 04-25-2006, 09:50 PM
madcow393's Avatar
Custom User Title:
Last Online: 03-23-2009 10:57 PM
I'm not saying it works or doesn't. I don't know, but mtk, have you tried using one at all? If so then okay. If not then give it a shot. It's easy to be a skeptic from the outside looking in. You have to dig in and find out for yourself if something is or isn't.
"That was simply my two cents you can take it or leave it." (Ruben)
Old 04-25-2006, 10:16 PM
madcow393's Avatar
Custom User Title:
Now, for a moment, if I may play devi's advocate:
I would like to say that the iCat was never invented as a preformance enhancing device. It is used in wharehouses that utilize loading machines to clean up their emissions. The idea behind the device is similar to that of the D.I.S. waste spark ignitions system that is now standard equipment on many modern cars. The idea is that the spark lasts long enough to burn off any gasses that were not used up during combustion. As the combustion has already taken place then there is no extra power to be gained by burning after the fact. The gains are environmental. The iCat was explioted beyond its original use. Like Dave said "Poor kitty".
Old 04-25-2006, 10:58 PM
kountryboy's Avatar
Last Online: 11-11-2009 06:56 PM
Ive got one on my xr400 and it seemed to make it pull a little harder through all the gears but that is about all. Im gonna try it on my yz250 one of these days.
Old 04-27-2006, 02:59 PM
mtk's Avatar
mtk mtk is offline
I don't need to try it.
That is the beauty of engineering school: you learn the laws of the physical universe and can evaluate a product without having to waste money on it.
Oh yeah, waste spark systems are not designed for emissions reasons; they were designed to use one coil for two cylinders instead of one coil per cylinder, saving parts.
Old 04-27-2006, 05:00 PM
Don't abbrev.
I completely agree with you...
Old 04-27-2006, 06:12 PM
Coopsvintageyz's Avatar
Last Online: 09-22-2009 05:42 PM
Man I never thought this thread would be this involved
Most of the things I have learned are from trial and error, because I couldn't find anyone that knew the exact answers for sure. So I guess sometimes there are no exact answers , so you just have to try.
So just maybe there is something about the ICAT that some people just don't know about, because there seems to be allot of people that think the ICAT has helped.
Old 04-27-2006, 06:35 PM
Don't abbrev.
Did you ever get a chance to do this?
Old 04-27-2006, 06:54 PM
I think you could have said," because I couldn't find anyone that knew the answer I was looking for."
Old 04-27-2006, 06:59 PM
Don't abbrev.
Yeah, that would've made more sense
Similar Threads for: Just installed the ICAT
icat 2smokeyz 2-Stroke Motorcycles - Yamaha 3 07-29-2007 06:58 PM
Icat?? matt_jasmine 2-Stroke Motorcycles - General Discussion 16 11-23-2005 01:49 PM
ICAT kickindirt114 General Discussion 1 04-24-2005 01:03 PM
ICAT ?????? NORTEXED 4-Stroke Motorcycles - Honda 22 10-29-2004 08:08 PM
iCAT Jason General Discussion 3 12-22-2003 04:41 PM
