Old 01-11-2017, 04:17 PM
bjunior's Avatar
novice
Last Online: Today 02:34 AM
Default idle problems on yamaha 250 - 2013
Hi on yamaha 250 t2 when i try to adjust idle screw i have screw almost all the way out still is idling to high.i set air screw 1 1/4 turn out
any thoughts on why idle screw is is not working right . have fun riding
also can the idle speed of motor be adjusted by opening or closing air screw ?
Old 01-11-2017, 06:04 PM
Last Online: Today 03:04 PM
There are a few things to consider on this issue.
1. Is the throttle cable routed correctly?
2. Is the throttle cable adjusted too tight?
( To test #1 & #2...Crank up the bike and put in on a stand. Then turn the handle bars from one side to the other. If the engine speed changes while doing this then you will find the problem in one of those.)
3. Has the bike set for a while? If so the pilot jet may have some trash in it causing a lean
condition which will make it idle high.
4. Yes the air screw can and will have an effect on the idle speed.
5. Is the fuel mix fresh?
6. An air leak at one of these points can effect your idle speed....
A. Carb manifold ( rubber boots)
B. Head gasket
C. Base gasket
D. Crank seals
Old 01-21-2017, 05:51 AM
arnego2's Avatar
^^^ this, nothing to add. +1
Similar Threads for: idle problems on yamaha 250 - 2013
ha yamaha yz 250 - 2013 bleeding coolant bjunior 2-Stroke Dirt Bikes - Yamaha 5 12-31-2016 01:24 PM
lowering a yz 250 yamaha -2013 bjunior 2-Stroke Dirt Bike Forums 6 04-10-2016 07:46 PM
HI yamaha yz 250- 2013 2t front sproket question bjunior General Discussion 4 03-21-2016 11:19 PM
on a yz 250 yamaha 2013 rear sproket bjunior 2-Stroke Dirt Bikes - Yamaha 5 02-16-2016 11:23 AM
2013 yamaha 250 2t bjunior 2-Stroke Dirt Bikes - Yamaha 2 02-09-2016 09:22 AM
