Old 10-04-2018, 03:24 PM
bjunior's Avatar
novice
Last Online: Today 01:42 AM
Default Hi k n air filter .
I have a 2013 yamaha yz 250 dose a k n filter work in a 2 stroke ? what are the pros and con s of it over a foam FILTER? . one con i know off hand is price. do u get longer life from a k n filter being made from a different material i think its some kind of metal mesh?
Old 10-04-2018, 04:39 PM
Last Online: Today 06:16 AM
I have used them, but I find the filtration is not as good as OEM. They also most of the time require some rejeting due to the increase air flow. I went back to OEM.
Old 10-09-2018, 08:08 AM
Last Online: Today 09:14 AM
Generally speaking, K&N filters flow more than their OEM counterparts, which means they filter less. I've found this is true for motorcycles and for cars. It depends a lot on where you ride and the types of environments you expect to encounter, but if you have a lot of fine dust or sand I would say the K&N is not a great idea.
Old 10-09-2018, 01:10 PM
Last Online: 11-25-2018 01:28 AM
I have used K&N filters on many different dirt bikes but, I must say for a simplistic use... I'd stay with the foam filter and get a 2nd one to use when you are cleaning 1 ...A good foam filter with a good clean & re-coating useing the right oil will trap more trail/track dirt's!
K&N is a good filter & does work but, I'd stick with foam !!
Old 10-11-2018, 02:42 PM
schwen_108's Avatar
Retired from offroad
Last Online: 11-22-2019 02:42 PM
I've spoken with our Honda Service rep about the pro's and con's of K&N airfilters. He told me the same things everyone else has mentioned so far. His words were a little more blunt to be honest. He flat out told me "I've seen K&N filters ruin so many top ends in my day that I'll never run one."
Which when I thought about it makes total sense. If the filter is letting more airflow through it, it also has to be letting more dirt through it. Dirt and internal combustion don't play well with eachother
Similar Threads for: Hi k n air filter .
Filter Oil kawaboy22 General Discussion 1 05-31-2010 11:09 PM
Is a pre-oiled filter a one time filter? Malcolmv8 2-Stroke Dirt Bike Forums 22 06-15-2007 05:26 PM
Air filter oil? 99RM250 2-Stroke Dirt Bike Forums 4 05-21-2004 12:04 AM
Oil filter for the YFZ 450? 2fun ATV/UTV Forums 17 05-20-2004 10:50 PM
air filter oil crfowner110 4-Stroke Dirt Bikes - Honda 1 02-15-2004 01:49 AM
