Old 03-21-2019, 04:37 AM
Last Online: 03-26-2019 01:40 PM
Exclamation Here we go... 1982 yz80j problems.
Hello everyone , I've recently bought an old yz80j. When I first got it and tried to get it started it ran but ran like poop (bogging hard) I then I put a new spark plug in and it ran a bit better but still would bog out at 1/4 - full throttle . So naturally I guessed carb clean and cleaned everything in carb completely. Jets looked like they'd been taken in and out a hundred times but didn't think much of it. Put it back together and slammed her back in the bike and tried it out. This time it ran a lot better and would sometimes hit powerband after cutting and bogging . So I thought surely it's the age of the carb so I got a new one.. now it idles and revs high with 1/4 throttle but still farts and coughs when full throttle is applied or bike is under load. I've messed around with air screw and idle screw but can't seem to find the sweet spot . I've moved the needle clip down 1 (3rd from top) and it helped a little but still bogs down if I apply full throttle and sometimes backfires back through Carby.. I've taken the reeds out and flipped them over and they seem like they are fine.. has a strong spark when I check it by hand so really not sure where to go from here... Can anyone shed some light . Cheers -Shae
Old 03-21-2019, 07:11 AM
Last Online: Today 07:01 AM
Put a timing light on it and make sure the timing is correct, consistant and not jumping around. At least eliminate that, but I do think it is carb related.
Old 03-21-2019, 08:49 AM
Last Online: 02-01-2020 09:53 AM
Low compression will cause these issues.
Old 03-21-2019, 01:44 PM
It's just had a new carb tho.. it's been cleaned etc too..
I'll have a look at timing after work but don't think it's that because it revs high and idles good when standing
I'll take a video after work of what it's doing
---------- Post added at 07:44 AM ---------- Previous post was at 07:43 AM ----------
It has good compression.
Old 03-21-2019, 05:03 PM
What is the compression reading?
Old 03-21-2019, 05:07 PM
I don't currently have a compression guage (I'll try find one to borrow ) but feels ok to me .. I've been able to kick start it once warm also . .
Old 03-22-2019, 09:49 AM
Last Online: Today 09:29 AM
Compression can "feel" ok even when the motor is on the low end of spec and on the verge of not being able to run at all. Judging compression by feel works as a basic diagnosis often times but when you're trying to sort out an issue like this knowing the actual compression value can be helpful. Or, at the very least it could help point you in the direction you need to go.
A couple other things to check- is the air filter clean and in good shape? Condition of the airboot between air filter and carb? Condition of boot between carb and reed block?
Similar Threads for: Here we go... 1982 yz80j problems.
1982 YZ80J exhaust Nicholson777 2-Stroke Dirt Bikes - Yamaha 6 05-16-2011 09:38 PM
RM 80 - 1982/3 Cymonc 2-Stroke Dirt Bikes - Suzuki 2 12-28-2010 08:12 AM
1982 lt 50 problems kralldaddie ATV/UTV - Suzuki 0 04-26-2010 03:54 PM
1982 Yz 125 Help!!!! Jordan #241 Vintage Riding 2 01-29-2009 10:16 AM
1982 CR250 ignition problems mcgyver1467 2-Stroke Dirt Bikes - Honda 0 09-24-2007 08:31 PM
