got a few stripped threadsThis is a discussion on got a few stripped threads within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Well, about 3 months ago I accidentally stripped the threads in the frame to one of the bolts that hold ... |
| Well, about 3 months ago I accidentally stripped the threads in the frame to one of the bolts that hold the radiator on. I JB welded it and it has been good ever since. I just havn't tried to take the radiator off. Today I was looking over the bike because I'm going riding tomorrow and noticed that one of the holes that holds the right fork guard on is stripped. I guess the guy I bought the bike from stripped that. How is an easy way to fix these? I dont realy need to but it would be nice just to have the bike in perfect condition. I'm thinking of re-tapping it but I want to keep the bolt head size the same so I can still use the 8mm socket. |
| retap it and put a helie coil in it.... |
Or you could tap it out a size larger and find another bolt with the new thread size AND an 8mm head. |
| How about a plastic tie down and some duct tape? Nah, all the above ideas sound great. |
| How about a thread chaser??? Sears sells them. Not as violent as a tap. It will sometimes help with threads like this. It looks like this, but costs much less because your buying only one size. [Only registered and activated users can see links. ] Helicoils are great. Autozone sells a metric "set" for about 25.00. It comes with the tool to insert them with and inserts. These things rock. I have several on my old 73 Honda. They have lasted for years. |
| I think my radiator is held on with plastic zip ties. I would probably drill it a size bigger and tap it, although anything metric can be a pain to find the right size. Can you drill it all the way through, use a longer bolt and put a nut on the other side? Use a nylon lock nut if you can find one. |
| stripped drain plug threads | 88CR250_Rider | 2-Stroke Motorcycles - Honda | 4 | 03-19-2009 11:52 PM |
| Stripped Bolts | FallingOsh | 2-Stroke Motorcycles - Yamaha | 13 | 07-04-2008 12:23 AM |
| Stripped Bolt | Fireman87 | 2-Stroke Motorcycles - General Discussion | 5 | 11-02-2007 11:22 PM |
| possible stripped brake pad pin | Sublimize23 | General Discussion | 11 | 07-17-2004 06:44 PM |
| stripped threads? what to do? | 04kx250 | 2-Stroke Motorcycles - Kawasaki | 7 | 07-16-2004 05:14 PM |
