GEARING!!!!!!!!!This is a discussion on GEARING!!!!!!!!! within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I need to know some info on gearing.
I run a 13/50 on my yz125. I also have a rythem ... |
| I need to know some info on gearing. I run a 13/50 on my yz125. I also have a rythem section at my house, it is a double, three whoops then another double. By the end of the last double i go nose high because my bike is reved out, and i cant shift up into third because the jumps are too close together. Can i make gearing changes to my bike where 2nd will last a little bit longer? But if i do will my bike still have the power is dose then like it dose now? thanks alot |
| Why don't you try shifting in the air? I guess you could do that if you took a tooth or two from the rear sprocket. But I am no genius at gearing. |
| You could gear higher, but I'm with ^^^ Just learn to shift in the air and your problems solved. |
| Drop down 1 to 2 teeth in the rear sprocket that should do it. |
| i agree with motomojo learn how to shift in the air or if your not good enough to do that move your jumps further apartblue |
| gearing on a 125 | Henry | 2-Stroke Motorcycles - General Discussion | 17 | 09-20-2007 11:54 PM |
| 03 yz gearing?? | seagrams83 | 2-Stroke Motorcycles - Yamaha | 7 | 06-26-2007 11:06 PM |
| gearing? | squizzleboy | General Discussion | 3 | 06-09-2004 06:12 PM |
| gearing my 426 | lcano | 4-Stroke Motorcycles - Yamaha | 2 | 03-24-2004 09:52 PM |
| Gearing! | 83SuzukiRM250 | General Discussion | 10 | 01-07-2004 10:05 PM |
