Old 10-06-2008, 08:28 AM
Last Online: 04-30-2009 11:44 AM
Default Gear Shift Oil Leak
hi i'm trying to find out if the engine needs to come apart to change whatever is making oil dribble from the gear shift spline on my yz125 04?
I can do track side maintenance, but any job needing proper workshop, i take in. I have an idea its an oil seal leaking, the service manual doesn't show that part. i'm thinking perhaps i can lever an oil seal outwards and replace it? (i haven't got my bike here)
any advice would be cool
Old 10-07-2008, 08:04 AM
MXtras's Avatar
Manufacturer Dude
No - you can extract the seal without splitting the cases. The shaft is in the way which makes it harder but it can be done. Just be very cautious not to booger up the case. One way is to thread in a few sheet metal screws into the seal (not too far) and use them to extract the seal. It pops out pretty easily.
The easiest way is to pull the shift shaft.
Scott
Old 10-07-2008, 10:51 AM
hi, scott, thanks. just to make a bit more clearer, which way does the gear shifter oil seal come out from? outside or inside? do i need any gaskets? i can't find any closes ups in the service manual it doesnt show it.
Old 10-07-2008, 11:42 AM
MXtras's Avatar
Manufacturer Dude
It pops right out from the outside.
If you do the job with the shaft in place, you will need no gaskets.
If you plan to pull the shaft, you will need to remove the clutch, so you will need the right side cover gasket and maybe a power valve cover gasket (I usually don't replace this gasket every time).
The seal is not really in there all that tightly. You will likely be suprised how easily it comes out. Just watch out not to booger up the place where the seal goes in - there is a small ledge around the seal and if it gets crushed over it can be a chore to get a seal in there without a leak.
Scott
Old 10-16-2008, 08:56 AM
Thumbs up
I finaly got a round to doing the oil seal yesterday. I was surprised how easy it came out. Thanks for explaining it!
Old 10-16-2008, 09:02 AM
MXtras's Avatar
Manufacturer Dude
Glad I could help and thanks for the update.
Scott
Old 10-16-2008, 01:20 PM
Bacardi23's Avatar
Last Online: 07-19-2010 04:20 PM
Hi there... and did ya check why the seal was leaking? did you hit with the shift lever on something hard like a...bike rock?
Vando
Similar Threads for: Gear Shift Oil Leak
shift 24k gold gear ktmkid358 Classified Ads 0 06-06-2008 09:58 PM
Gear Shift Lever problem pdmoyes 2-Stroke Dirt Bikes - Honda 8 10-18-2005 06:35 PM
Gear shift..weld or not? RICHIE500 2-Stroke Dirt Bike Forums 26 10-03-2005 12:42 PM
shift gear is horriable!! Mr.Boof General Discussion 14 10-19-2004 03:10 PM
Crashed, Wont shift into 2nd Gear vaulta 2-Stroke Dirt Bike Forums 9 05-20-2004 01:40 PM
