Old 01-05-2019, 10:02 PM
bjunior's Avatar
novice
Last Online: Yesterday 10:23 PM
Default fork seal leak
On my yz 250 when i push up and down there is a very very light ring of oil dose that mean its time to replace seals?On down tube is it supposed to dry no oil?
thanks
Old 01-05-2019, 11:55 PM
Last Online: Yesterday 07:40 PM
Time for a rebuild with seals, dust wipers, bushings and oil.
Old 01-06-2019, 12:34 AM
bjunior's Avatar
novice
Hi do they make a kit that includes all those parts?
Old 01-06-2019, 07:07 AM
Yes
Old 01-07-2019, 06:36 AM
Last Online: 03-19-2019 11:02 AM
Most likely you'll need to rebuild but not every time you see that will you have to. Sometimes you need to clean the seals. Moton pro makes a little peiece of plastic that you slide up there and use to clean it. It can also be done with something like 35mm film. Usually you have to pull the dust seal down, slide it in between the fork tube and fork seal, and then run it around the fork tube. Once you do that then you compress the forks a bunch of times and repeat until you see no more oil. I've had it take 10 or so times repeating that process before they seal. Then I'll take some lithium grease and put it in between the dust seal and the fork seal. You'll see a little of that when you push down on the forks again but that will slowly go away also.
Old 01-07-2019, 08:28 AM
Last Online: Yesterday 08:14 AM
Cleaning under the seals can usually buy you a little time, but from my experience with trying to that it's basically a band-aid fix. It definitely won't hurt to try though. Expect some oil to gush out when you are doing it though.
Similar Threads for: fork seal leak
Fork seal leak fix-need suggestions! stevo450 General Discussion 6 11-22-2014 02:41 AM
06 crf250r water seal leak leirhiht 4-Stroke Dirt Bikes - Honda 7 07-24-2013 07:57 AM
2003 kx 250 fork oil and fork seal service wera917 Dirt Bike Suspension Tuning 4 02-04-2007 08:26 PM
CR 250 2003 air box seal leak coss 2-Stroke Dirt Bikes - Honda 5 09-17-2004 09:35 AM
CR 250 2003 air box seal leak coss 2-Stroke Dirt Bikes - Honda 0 09-17-2004 04:56 AM
