flywheel weight?
This is a discussion on flywheel weight? within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; I'm thinking of gettin a flywheel weight for my 05 yz125 and wondered what weight you guys would sugjest.I think ...
Old 03-16-2005, 08:53 PM
mad_biker's Avatar
blue (or yellow) is better
Last Online: 10-27-2009 07:35 PM
Default flywheel weight?
I'm thinking of gettin a flywheel weight for my 05 yz125 and wondered what weight you guys would sugjest.I think they make 7, 9 ,and 11 ounce.Oh and I ride mostly in the blue ridge mountains.
Old 03-16-2005, 09:01 PM
LoKi's Avatar
Long Live the Goat
Last Online: 01-12-2009 06:29 PM
Default Re: flywheel weight?
I have a 11oz Steahly on my 01 KX250. I love the way it handles now. I would think a 9oz would be sufficient for a 125. They really help all around. It's like night and day riding my bike now. I ride trails alot, but have taken back to riding MX. Overall, my bike still has the snap when I want it, and keeps the power on the ground.
Spitfire's Avatar
Banned
Last Online: 08-10-2006 02:25 PM
I know it doesn't apply to your '05, but it should give you an idea of what you'll need.
Old 03-16-2005, 09:11 PM
Silver_Fox's Avatar
Wut the?
Last Online: Yesterday 11:49 PM
Read this thread, it may help.
MXA - Flywheel Answers
Old 03-16-2005, 11:07 PM
Logik's Avatar
Last Online: 05-03-2008 12:06 PM
woah, awesome chart.
Old 03-17-2005, 09:26 AM
souphmars's Avatar
Last Online: 02-25-2009 11:57 PM
i have an 9 oz on my RM250, and it does just fine- i like it a ton better in the woods now with the weight- i am considering the next heaviest weight which is 11 oz, but i am way satisified with what i have now- especially when climbing a hill, i can tell a big difference- u won't have to fly up the hill anymore, although i still choose to- LOL
Old 03-17-2005, 09:30 AM
Last Online: 01-24-2010 12:13 AM
I think the chart says it all. The more weight, the smoother the power. The less weight, the less change you will notice in the power delivery.
Old 03-17-2005, 08:56 PM
mad_biker's Avatar
I think I will go with the 9 oz one cuz I ride in a lot of trails and mud but don't want to loose too much acceleration because I ride some fast trails too. Thanks for yall's help
Old 03-17-2005, 09:33 PM
LoKi's Avatar
Long Live the Goat
You won't lose any acceleration. It slows the revs a bit and puts more power to the ground versus just spinning the tire. It's still all there when you want it.
Old 03-20-2005, 05:32 PM
YZER-409's Avatar
Last Online: 07-25-2005 08:44 PM
What does changing the flywheel weight do to your bike.
Old 03-20-2005, 07:00 PM
souphmars's Avatar
lemme take a shot at this- if u add weight, it will make the engine rotate slower, and give it a added inertia- which makes it harder to stall it- it also decreases wheel spin, kind of makes it hook up better- u can also lug on it a bit more- some people say it adds bottom end, which is not true- it doesn't change the engine like that, or move any power- if u put a lighter flywheel on a bike all these things would change- if i am wrong other people on will correct me
Old 03-20-2005, 07:10 PM
LoKi's Avatar
Long Live the Goat
When we started making flywheel weights in 1987 very few riders understood the benefits of adding flywheel weights. Since then the popularity of adding flywheel weights has increased dramatically. More and more riders discover that they can go faster for longer with the smooth power delivery, better traction, and reduced stalling that Steahly Flywheel Weights provide. Adding a flywheel weight will increase the rotating mass, or inertia, of the motor. The result is an engine that is a little slower to rev, has more controllable power delivery and less hard hitting power, a more usable low to mid-range, and is less likely to stall at slow speeds or with the rear brake. What you will feel is better traction when it is slippery or hard pack, a torquier and broader powerband, the top end power on many bikes will be improved with less tendency to lose RPM's when climbing or hitting obstacles. The easier to control power will help you conserve your strength and energy, plus many bikes start easier with the added weight. Most Steahly Flywheel Weights screw over top of the stock ignition flywheel using our exclusive patented mounting system. Most can be installed in less than a half hour without removing the stock flywheel from the engine. Our weights are also easily removed so you can change the power delivery back to stock for different riding conditions. Steahly Flywheel Weights are machined from solid steel billet on computer operated lathes for the ultimate in balance, trueness and strength. Our weights are designed to fit each specific model of motorcycle for a close fit and best possible performance. For most models we offer several different weights so you can choose the amount of weight to suit your riding style and conditions. Generally for a fast, aggressive rider or for faster terrain a light to medium flywheel weight would be the best choice. For a slower more casual rider or for riding slower technical terrain a heavier weight is ideal. Call us and we will be happy to discuss your situation and make suggestions. We also carry a wide range of other off road accessories, many of which are special or hard to find. All of us at Steahly Off Road are serious dirt riders and racers and the products we sell have been used and tested under real riding and racing conditions.
C h u c k S t e a h l y
Steahly Off Road
Owner, Founder.
Old 03-20-2005, 07:15 PM
souphmars's Avatar
good post loki- what is said about climbing is way true- that is where i tell the biggest difference- ride a factory bike or something w/o a flywheel weight up a tall or long hill- then ride 1 w/ a flywheel weight, u can tell a major difference
Similar Threads for: flywheel weight?
flywheel weight. A5spdTaco 2-Stroke Motorcycles - General Discussion 17 07-04-2008 10:40 AM
flywheel weight MPera669 2-Stroke Motorcycles - Honda 9 06-23-2008 10:56 AM
flywheel weight 01 yz 250 rudiger701 2-Stroke Motorcycles - Yamaha 5 03-17-2008 03:21 PM
flywheel weight 99RM250 Wanted Items 0 05-08-2004 08:44 PM
Flywheel weight on a YZ 80? Snowsk5054 2-Stroke Motorcycles - Yamaha 9 04-08-2004 02:28 PM
