dt 175 ignition wires bypass help plzThis is a discussion on dt 175 ignition wires bypass help plz within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Hi all great forum
dose anyone know what wires i need to join to bypass my now broken ignition on ... |
| Hi all great forum dose anyone know what wires i need to join to bypass my now broken ignition on a yamaha dt175 y reg ignition wire plugs are first plug wires Black Black+white Brown Blue+red Red second plug Yellow Yellow+white Red+orange White it would be great if anyone knows what wires i can join to get it going again as i have tryd and tryd to find out what wires i should join to let it run and my son is nipping at me to get it going again and being i live in the top of scotland bike shops are a bit scarce thanks all in advance |
| The black wire with the white stripe from the stator goes to the coil, but if you hook it up without a switch in between then you won't be able to shut it easily if the throttle gets stuck open (it's happened to me) which could be dangerous so put a switch in there. |
| thanks for that i got it running just had to unplug every thing it now starts no problem like you said i will need to shut it of i will conect a switch in there now i know where from nice one thanks for the info |
| 85 rm 125 stator wires | ridedemall | 2-Stroke Motorcycles - Suzuki | 4 | 03-12-2009 02:55 PM |
| oil enjection bypass? | jon morse | 2-Stroke Motorcycles - Yamaha | 12 | 10-10-2007 02:58 PM |
| 99 CR 250 IGNITION | micro101 | 2-Stroke Motorcycles - Honda | 0 | 06-22-2007 03:34 PM |
| FMF Ignition | 99kx250rules | General Discussion | 7 | 06-12-2005 02:39 PM |
| FMF AOF Ignition | Shocknut | Performance Mods, Maintenance, & Lube | 4 | 09-25-2003 11:24 PM |
