Old 01-20-2010, 10:41 AM
Last Online: 06-05-2010 03:40 PM
Default dt 175 help
I found a bad rubber washer in the carb and now fire up first kick but when trying to run throught the gears it backfires past half throttle .. any ideas .. I thought timing but when I take off left cover it looks like greek to me.
Old 01-20-2010, 02:18 PM
VAL's Avatar
VAL VAL is offline
Last Online: 03-28-2018 10:50 AM
Might be Jetting. Or it could be the High speed coil or CDI or Main coil.
Start off with jetting, seeing as how your original problem appears to have been an air leak. Try running with the choke on. If the problem subsides, your runnin too lean. If it gets worse, it might be too rich.
Wait, what washer did you replace in the carb?
Old 01-20-2010, 02:27 PM
thet bike used to run then was parked .. the rubber ring was on the needle valve where it seats into the bowl. I can play with it in the morning but dont think it mattered if the choke was out, where is the high speed coil? and what does the cdi do? Prior to fixing this ring I couldnt get it past a quarter throttle once in gear but in nuetral I could rev it from idle to full with no hesitation.
Old 01-21-2010, 08:09 AM
VAL's Avatar
VAL VAL is offline
Well, first off, lets stick with jetting for now seeing as how a change in the carb made a change in performance.
I see you are in colorado. Is the weather very cold? The reason I ask is the colder the air temp the more dense the air and therefore the leaner the fuel mixture.
Let us know how the Choke run works and we can go from there.
To answer your other questions, I automatically thought your bike is a late 70s model so I thought you would have that ignition system. In that system there are two coils that feed charge to the CDI (Capacitive Discharge Ignition). One coil (larger of the two) supplies power at low speeds and the other smaller coil give a bit more juice for higher speeds.(I got a interesting story on that if you are interested) These coils are located behind the flywheel.
If I got the model year wrong things might be a bit different.
Old 01-22-2010, 04:07 PM
ok so just to clarify its a 78 dt 175 with mikuni carb the oil injector has been plugged .. so I tried it today fired right up first kick so i put it in gear and headed down the road it sputtered as i made it to about half throttle then started its popping so i opened the choke and it died. I then preceded to try to start it and at the end of every other kicked it popped or backfired but sounds more like a pop to me. it tried to start after about 15 trys but would not completely start so I then had a great time pushing it home. I'm so confused now .. yesterday I took apart the flywheel and inspected the points I cleaned it all up and ran some fine grit sandpaper over the end of the coils and magnets they had some residue on em and cleaned up what I think is the advance that was on the flywheel side tucked into the magnets, I felt confident in how it looked so put it all back toghether and it fired right up I thought i had it but was too cold to try, but dissapointment waited till now to show its ugly face. I'm soo lost with this little motor I have knowledge in cars and some common sense that tells me this shouldnt be this hard for me to figure out but I guess a tiny 2-stroke is tougher than I thought,
Old 01-22-2010, 04:51 PM
VAL's Avatar
VAL VAL is offline
Originally Posted by thatdamnabe View Post
.. yesterday I took apart the flywheel and inspected the points I cleaned it all up and ran some fine grit sandpaper over the end of the coils and magnets they had some residue on em and cleaned up what I think is the advance that was on the flywheel side tucked into the magnets,,
There shouldn't be "points" on a 78 DT 175, nor should the be a centrifical advance. You should see..
4 and 5 are your low and high speed coils, 6 is you lighting coil and 10 is you pulse coil.
I had a similar problem after putting in two remanufactured coils from Ricky Stator. As it turned out the problem cleared after the wire between coil 5 and the CDI were disconnected. (This may not be the case with your bike)
Sorry about the choke method, that usually helps figure out if its a jetting problem.
Old 01-22-2010, 07:49 PM
ok so is this the same as the schematic
and this is what I thought was an advance
and this is a level picture is my carb too tilted if so how in the world do i fix that
when I took this off I noticed gas inside on the bottom i think you can see it in the pic of the carb what you think can this be the problem?
Old 01-22-2010, 08:40 PM
Last Online: 07-29-2015 03:18 PM
Good luck I have a 1972 175 ct2 that did the same thing to me several years ago. Now its been collecting dust in the shed since about 1999. I will keep tabs on this topic to see if you ever got it fixed and what the problem was. Some day I wanna get it back running it was a blast to ride.
Old 01-23-2010, 08:23 AM
VAL's Avatar
VAL VAL is offline
Ok, we got a couple of issues going on here. Lets start with the latest revelation. The gas in the flywheel area is an indication of a bad crank seal. Dont worry , they can be replaced without taking the motor apart. If this one is leaking its SOP to replace both at the same time. If you are leaking gas, then you are also leaking air when running, which makes the fuel mixture too lean, and could be the cause of the original problem, but before you do anything in the jetting or timing departments, these seals need to be changed.
Second, I dont think you have a 78 dt. It looks like you have the older point and advance setup for your ignition 76 was the last year that Yamaha had that type of magneto/point set up.
This is the 1975-1976 DT
This is the 1978 DT
There is a gap in 77 as far as model, dont know if they stopped for a year or just sold 76s as 77. Any hooo, you can see the difference in the motor with the radial fins and CDI ignition.
Do you have a manual for the bike?
Old 01-25-2010, 01:14 PM
Wow your good .. so the title states 78 but I thought you took a picture of my bike in someone elses garage, my bike must be a 75-76 its exactly the same as the pic minus a dent in my tank. So I dont have a manual is there somewhere I can learn how to fix these seals? I'm gonna call around and see if I can find those seals for a 75-76 instead of a 78.
Old 01-25-2010, 01:28 PM
VAL's Avatar
VAL VAL is offline
Here is a pic of the 76 mag and points
So that kinda seals the deal with the model year
the 78 looks like this
: Left Seal:
OIL SEAL,SD-TYPE 358444-001 $6.26
Right Seal
OIL SEAL,SW-TYPE 305988-001 $6.26
If you cant get them local, BikeBandit.com can.
Double check your model number on your title. is it DT 175 C?
Old 01-25-2010, 01:33 PM
title says dt1 but vin is a 443123640 not sure if i can find the true year with that number .. so do i do both if so .. how?
Old 01-25-2010, 01:48 PM
VAL's Avatar
VAL VAL is offline
I think you are missing some numbers, I beleive the 70s to 1981 had 13 digits and after that they went to 17.
Take a look at the engine number. Might be stamped on the clutch cover or near the shifter.
Old 01-25-2010, 02:02 PM
That's the right number stamped behind the forks and on the clutch cover
Old 01-25-2010, 04:06 PM
VAL's Avatar
VAL VAL is offline
OK I found it. Its a 1975
Yamaha Vintage Dirt Bike I.D. Guide - - Dirtbike at Off-Road.com
It looks like there wasnt any changes in basic design and I checked the part numbers for the seals and they are the same.
So I am wondering if you and I suffer from the same eye condition. If I dont wear my glasses, a 5 looks allot like a 8.
Old 01-31-2010, 07:45 PM
Ok so I ordered the seals they should be here tomorrow so how do I do this now do I just start taking things off?
Old 01-31-2010, 09:08 PM
VAL's Avatar
VAL VAL is offline
once you get the covers, flywheel, stator plate, clutch and primary gear off, you will carefully pierce the old seals between the inner and outer diameter with a punch or small screwdriver, being careful not to go too deep into the bearing areas or hitting the case or shaft. Once you have the holes, use a small screwdriver to pry the seals out. New seals get a dab of greas on the inner diameter and gasket cement or lock tight on the outer. Drive them on with a piece of PVC or if you have a deep enough socket, that is large enough to transfer the force to the outer diameter. Tap the socket or PVC with a mallet being careful to dive the seal on evenly.
Old 02-05-2010, 07:31 PM
Holy smokes it just might work now I only road it down the street and back but I think it worked .. I'll post again tomorrow
Old 02-06-2010, 08:42 PM
Well that was it thank you for all your wisdom Val I appreciate all. Now is there a way to straighten a front wheel I got running and felt a wobble looked down and the wheel is all out of whack.
Old 02-06-2010, 10:09 PM
VAL's Avatar
VAL VAL is offline
I am glad you got her going. Its nice to hear.
As far as your front wheel, it can be straighten if it is just a matter of loose spokes. If it is damaged, that's another story.
Easy way to straighten if it is merely spokes is set the bike up so the wheel spins freely.
Looking straight at the rim and using the forks as your referance for center, adjust the spokes a little at a time. Be careful and watch what you are doing. Some people go over board on the first few adjustments and then cant get back to normal. Make sure you can look and understand which side pulls the rim which way. Again a little at a time and spread the adjustments over many spokes, not just one. When finished. spin the wheel and tap the spokes, listen for a uniformed sound. If your front hub is conical, you will have a different tones for the short pokes and long. Take your time, a little at a time.
