clutch will not engage
This is a discussion on clutch will not engage within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; i have a friend with a 95 yz125-his clutch will not engage so he change gears-what i mean is with ...
Old 09-17-2004, 09:07 PM
souphmars's Avatar
Last Online: 02-25-2009 11:57 PM
Default clutch will not engage
i have a friend with a 95 yz125-his clutch will not engage so he change gears-what i mean is with the clutch pulled, he goes to shift a gear, bike jumps then dies-he has changed the oil, smoothed the grooves in the clutch basket-i told him i would replace the plates, and cable-what do yall think-thanks
Old 09-17-2004, 11:04 PM
Thumprding's Avatar
Last Online: 01-09-2007 07:36 AM
Default Re: clutch will not engage
From what you describe it sounds like the clutch won't disengage. Make sure the lever free play is set to about 1/8" and try it again.
If that won't work you may have to look at putting a shim on the push rod that the disenages the clutch.
Old 09-18-2004, 12:03 PM
Thumprding's Avatar
What I mean by a shim.
When you take the pressure plate off right in the center of the clutch hub should be a rod. The rod extends all the way across the motor to a small cam that is rotated by the clutch cable.
Now some times the cam and or the rod wears. On the rod there is normally a bushing or cap that pushes against the pressure plate. The rod normally does not push against the center of the pressure plate. The cap it fits over the rod. What you can do is take the cap off, drop a small steel washer in the cap and put it back over the rod. This will take up the wear.
Similar Threads for: clutch will not engage
Hebo clutch/ Reluse clutch tchui General Discussion 8 11-21-2007 11:34 AM
Clutch cable replaced, but clutch won't work anymore... 96kx125 2-Stroke Motorcycles - Kawasaki 1 07-31-2007 06:16 PM
5TH GEAR ON YZ250 DOESN't ENGAGE!! HELP!! camaro80r 2-Stroke Motorcycles - Yamaha 1 07-03-2007 03:59 PM
New Clutch Lever wont Engage clutch khyz250 2-Stroke Motorcycles - Yamaha 2 01-14-2005 03:17 PM
Clutch probs- clutch wont dis engage. HELP EliteDetailOC 2-Stroke Motorcycles - Yamaha 13 02-02-2004 11:14 AM
