![]() Hi all!! bought a 2001 YZ 250 last summer (nice upgrade from the '81 IT 250) took it out for its first ride this year, got into some wicked clay, jumped the chain 2 spocket teeth and toasted the clutch. I bought a DK clutch kit with friction plates, clutch plates, springs + got a jug of 80w oil. I was wondering what the specs for springs, clutch nut, cover etc. was. Bought bike private sale and haven't got a manual yet. Bike will still move but when powerband kicks in, it slips. Is there a way to tighten clutch and get last bit of use of clutch or should I just change? thanks. |
![]() You can loosen the cable so it engages all the way, but you will essentially have Zero clutch for starting and stopping. So the bottom line is to just change them out. |
![]() What Woody said.... however changing the clutch on a new bike is so quick and easy you can do it in about 15 minutes without even draining the tranny oil. Lay it on the left side and pull the clutch quick cover off. On my ole 125 it was 8 x 8mm bolts and then 5 x 10mm through the pressure plate and done.... Thanks Scott |
![]() Yeah it is a really easy job. I've now done two of them and going to do the next one in about 2 weeks. Very easy job. |
![]() Thanks guys. Any guess on torque specs for springs, clutch bolt, cover? |
![]() It's not much. My 2006 YZ125 shows 10Nm and 7.2ft/lb for the case bolts and springs. I don't know what clutch bolt you speak of. I would think those should work, but maybe someone else will chime in. |
![]() Thanks. didnt wanna overtighten springs ![]() |
Thread Tools | |
2000 rm 250 clutch spring torque specs? | bbeach80 | 2-Stroke Dirt Bikes - Suzuki | 1 | 07-20-2010 11:49 PM |
96' CR250 top-end & clutch job...need torque specs and other info? | Jackal | 2-Stroke Dirt Bikes - Honda | 27 | 10-02-2008 01:43 PM |
clutch torque specs | rudiger701 | 2-Stroke Dirt Bikes - Yamaha | 0 | 02-15-2007 09:51 PM |
Clutch Specs - 99 Honda CR125R | drb | 2-Stroke Dirt Bikes - Honda | 0 | 06-28-2006 12:47 PM |
Tight clutch cable and torque specs | Hybrid | 2-Stroke Dirt Bikes - Kawasaki | 0 | 06-07-2004 12:48 PM |
