clutch-push rodThis is a discussion on clutch-push rod within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Hey, first time workin on the clutch. On my bros 03yz125, the clutch cover threads where the oil check bolt ... |
| Hey, first time workin on the clutch. On my bros 03yz125, the clutch cover threads where the oil check bolt is was stripped and so were replacing the clutch cover. I have a question about the push rod. I noticed it is pretty loose and I can push it in and pull it and move it around somewhat. Does that need to be in a certain position before installing the push lever to it? I know the teeth on the rod should be facing backwards, but other than that, should it be pulled or pushed back or what? I put everything back together and pulling the clutch is extremely loose, and I think the pushrod is the problem, or maybe I just put it back together wrong. Any help appreciated. I pretty much dont know what Im talking about, so if Im not making sense, Ill try and make things clearer |
| OT...Street bike clutch | DRGSin393 | General Discussion | 31 | 08-29-2006 09:37 AM |
| CR500 CLUTCH SPRINGS OR CABLE OR ROD? | DAVOS99 | 2-Stroke Motorcycles - Honda | 8 | 06-23-2004 06:41 AM |
| New Clutch Mod | Thumper426 | 4-Stroke Motorcycles - Yamaha | 2 | 05-07-2004 03:23 AM |
| Fixing the 2000 YZF426 Clutch | egoallenpoe393 | 4-Stroke Motorcycle Knowledge Base | 3 | 02-26-2004 01:44 AM |
| 01 Clutch Fix | cowboyona426 | 4-Stroke Motorcycles - Yamaha | 2 | 05-01-2003 11:49 AM |
