Cluch basket play
This is a discussion on Cluch basket play within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; The clutch basket on my '03 yz250 has some play that is noticable with the plates and everything installed. It ...
Old 10-21-2009, 10:27 PM
2strkyz's Avatar
Last Online: Yesterday 11:47 PM
Default Cluch basket play
The clutch basket on my '03 yz250 has some play that is noticable with the plates and everything installed. It has been like this for some time and seems to work but it just does not seem right. I know the nut holding it all together is tight but it bothers me for anything to feel loose in the transmission. I feel like I'm overlooking something obvious so any suggestions would be awesome.
Thanks
Old 10-22-2009, 11:28 AM
Last Online: 10-23-2009 07:40 AM
In most cases we'll feel some gear lash between the clutch basket gear ring and the primary gear on the crankshaft. If the clutch side crank case cover is removed you should be able to view the movement between the two gears.
Old 10-22-2009, 12:16 PM
MXtras's Avatar
Manufacturer
One thing to consider is that it's kinda loose when you check it, but you are checking it cold or at least cool. When things heat up, those clearances change. I am sure the engineers consider all areas of thermal expansion when the production clearances are determined so their machine doesn't lock up when it gets up to operating temperature.
Scott
Similar Threads for: Cluch basket play
Clutch Basket Play dangerSteve 2-Stroke Motorcycles - Honda 5 02-10-2009 08:18 AM
Play in con rod lt 50 iash101 ATV/UTV - Suzuki 4 01-16-2009 08:39 PM
kx 250 clutch basket play danpeltz 2-Stroke Motorcycles - Kawasaki 18 08-18-2008 10:55 AM
XR250 cluch problem chop8top 4-Stroke Motorcycles - Honda 3 12-23-2003 10:37 PM
Pay To Play motorox 4-Stroke Motorcycles - Honda 13 10-11-2003 10:53 AM
