BoggingThis is a discussion on Bogging within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; My 02 yz 125 boggs when i get on it till i get close to the power band. Also if ... |
| My 02 yz 125 boggs when i get on it till i get close to the power band. Also if its sitting at idle and i rev it up real quick, it bogs and then revs up. What should i do in order to eliminate it? I put in a #27.5 Pilot jet in but it still boggs. I'm gonna rebuild the top end before the end of march. any help appriciated. thanks |
| How ws it running the last time you rode it? Just to see if it is lean or rich turn the air screw all the way in. The idle should drop and maybe even stall. If that happens then the pilot jet is probably about right. if nothing happens, the pilot is probably to lean. What are your temps there? The colder it is the leaner it will run. Also check for an air leak. |
Thanks Justin |
| It can be bogging because it is too lean, bogging is not always caused by too rich conditions. Since it is bogging in the low end, I would expect that it would foul plugs too often if it is too rich. So if it is not fouling plugs, It is more than likely too lean. Your problem could be your float level, or air leaks from crankshaft seals or intake seals. Check all these before you rejet. If these are all good and it still bogs, try a richer pilot jet. |
| If your bike was bogging before, and it is still bogging after going with a smaller pilot then it is more than likely too lean already. Go with a pilot jet 2 sizes bigger than the one that you originally took out and I bet it solves your problem. Are you running an aftermarket pipe? |
| From what you are describing it sounds like a lean characterisitc. I would try a richer pilot (book mght call it "slow" jet) than the first, since the pilot jet and air screw control your 0-1/4 throttle position, and (from your description) thats where it is bogging. |
thanks |
| What elevation are you riding at? Also, make sure that your air cleaner is clean and well taken care of and not over oiled or you can cause some serious confusion with jetting. Does it bog less with the choke on? Does it run better when cold than when hot? |
| MY old yz 125h did the exact same thing. Now I dont know if there is a big difference between my old yz and your newer one. But I found out it was my crankshaft seal. I put my ear up were the stater was and I kicked it over and I could here the air coming out of the crankshaft. I just popped out the old one and put a new one in. And it ran really good. |
| The crankshaft seal is definately another thing to consider. The seals are reletively cheap and a pretty good insurance policy before you go and play with your jetting anymore. Good luck man, let us know how it goes. Another thing to consider too now that I am thinking about it is if it is really cold where you are, the bike wont run quite right and will be really cold blooded and boggy. |
| bogging i think | daveythewavey19 | 4-Stroke Motorcycles - Honda | 4 | 11-20-2007 10:10 AM |
| bogging out | motocrossjake12 | 4-Stroke Motorcycles - General Discussion | 3 | 06-13-2007 07:12 AM |
| CR 125 bogging on low-end | Forgiven96 | 2-Stroke Motorcycles - Honda | 20 | 02-25-2007 11:20 AM |
| Bogging Out!! | Matt3126 | 2-Stroke Motorcycles - General Discussion | 8 | 05-25-2006 10:30 AM |
| Bogging Down | kd2310kd | ATV/UTV - Yamaha | 8 | 03-22-2006 04:53 PM |
