any1 with a yz250This is a discussion on any1 with a yz250 within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; please post ur year, the jet setup in ur carb, and the air screw, and the clip on the needle-also ... |
| please post ur year, the jet setup in ur carb, and the air screw, and the clip on the needle-also reeds, pipe, and silencer, and ur mix ratio, and brand of oil-just want to do some comparisons-thanks |
| does nybody have a yz250?? |
| I have one, but my jetting is still out of wack, so don't want to post until I get it dialed. I can tell you, it's a 96, Mobile MX2T @ 32:1, boyesen reeds, stock pipe, FMF PowerCore2 SA. |
| a buddy of mine has a '99 yz250. he runs belray h1r at 40:1, vforce 2, fmf fatty, fmf shorty. i'm not sure what jet sizes he's running or how many turns out the air screw is. if you're wanting jetting comparisons, you might also want to ask elevation as well. here in dallas we're between 500-700 feet above sea level. -Z |
| 2001 YZ250, 32:1 yamahalube 2-r. PC works pipe and 304 silencer. Stock jetting with 2 up on the main jet. |
Just about every year Yamaha has different jetting specs to go with the updated motor changes. |
| '02 YZ250 Stock Jetting (Perfectly brown @ ~1500 ft.) FMF SST Pipe VForce 3 Reed Valve Yamalube 2R @ 40:1 Premium Pump Gas (California 91 octane) Pro Action Suspension (Awesome, tracks perfectly now) |
| 03 YZ 250 Jetting N3CG mid position Main 178 Gonna put a 180 in as cooking pistons! (not going hard enough) Pilot 50 Plug comes out dark brown from flat out to stop! Pro circuit pipe and silencer Silkolene Comp2 @ 32:1 Reeds stock Motul gear oil Forks and shock resprung! No complaints! Forks set right down! 14/50 on the chain Mobile Boost stickers (cause they look cool!) Needs a better rider than me! All in all an Awesome bike! |
| Hi All, 2004 YZ250wr Main Jet - 178 Pilot Jet - 50 Air Screw - 1.5 turns Needle - 2nd clip but not sure of which needle its stock Motul 800 mixed @ 33:1 Fuel - premium unleaded pump gas (98 octane) ALT - 100-200meters above sea level Sprockets - 14 - 50 Stock Pipe Stock Muffler Stock Reeds. This is a great bike but it can be a bit of handful as this is my first bike that i have ever owned so its taking a bit of time to use to. Cheers. Fastone. |
| any1 know sum Good websites to get pre-printed backgrounds | daviator101 | 2-Stroke Motorcycles - Honda | 2 | 07-17-2008 05:58 PM |
| Has any1 heard anything about the 07 YZFs? | 01KX125Ryder | 4-Stroke Motorcycles - Yamaha | 12 | 05-15-2006 01:59 PM |
| YZ250 or 450 Oh man which one | UnsafeHaven | 4-Stroke Motorcycles - Yamaha | 23 | 12-04-2005 08:21 PM |
| Any1 ride 85s | racer_ryan247 | Misc Riding Types | 7 | 08-05-2005 07:55 PM |
| any1 used a power now | souphmars | 2-Stroke Motorcycles - General Discussion | 8 | 02-19-2005 04:57 PM |
