Any Help?! ASAP Please!
This is a discussion on Any Help?! ASAP Please! within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; G"day guys. I am in a bit of trouble concerning my YZ. I put it back together last night after ...
Old 04-05-2005, 11:13 PM
Aus_Rider_22's Avatar
Mod From Down Under
Default Any Help?! ASAP Please!
G"day guys.
I put it back together last night after top-end rebuild and adding some parts. (bars, clamps, ignition)
This morning I went out and it started 2nd kick no worries. I rode it around for about 10 mins before killing it and putting it in the shed to cool down. I came back out aout 45 mins later to have a look at spark plug and adjust air-screw.
I wanted to check my spark plug as I have just moved the clip up one. So it should run slightly leaner. I am pretty sure that by leaning it out a bit the bike runs cleaner and stronger than ever before. No more oil coming out of silencer at all, at this stage. And the sparkplug is usually really oiled up. This time it's just slightly wet but not oily like it used to be!
So now I adjusted my air-screw back to manual's specs. (1.5 turns out) I thought I would give this a go and change it after testing it again.
Well, it won't start now!
Adjusting the air-screw couldn't make that much of a difference to starting it could it? The only thing that made me consider adjusting the air-screw was that it wasn't idling well. It kept wanting to die out on me.
So does anyone have any pointers or things I could try. The air filter is clean. I have tried numerous spark plugs and they all spark while hooked up to my bike. ( I thought wiring or electrics might have been bumped) Fuel is getting into the carby. THe tank hose is not clogged.
The only thing that I haven't checked is float. That was the first thing I went to do but the 3 bolts are star-screwdriver ones, and they have been done up very tight. I have tried and so has my dad and we can't get them out. I am worried about cross-threading the heads so I have left them alone.
Could the float change starting manners like my bike shows?
I have tried run-starting the bike to no avail. If I kick it or try and run-start it, then check the plug, it's kinda oily.
Does anyone have any suggestions for me?
If worst comes to worst I will probably take the carb into show to get them to undo bolts and reset float.
Thanks for your help!!!
Old 04-05-2005, 11:30 PM
Kenny400's Avatar
Proud Papa
Last Online: 11-03-2009 12:35 PM
Default Re: Any Help?! ASAP Please!
Have you tried setting the airscrew back to where it was when it was running?
Old 04-05-2005, 11:51 PM
Mod From Down Under
Yep, I changed it straight back when it wouldn't start as I thought that I adjusted too much, but it mustn't be the case.
I am gonna go back out and work on it again.
Thanks for your reply!
Old 04-05-2005, 11:56 PM
Kenny400's Avatar
Proud Papa
Hey..before you do..put in a new plug and pull the airfilter and give it a little shot of ether(starting fluid) if you have some. If it won't attempt to start on that, something is going on with your ignition. Didn't you just change it out to something else?
Old 04-06-2005, 01:16 AM
Mod From Down Under
Ok, I have made some progress.
It starts, but runs poorly down low.
By this I mean that it wants to bog down and die unless you a high in the rev range. Unless my revs are up it will just bog down when the throttle is opened up. It bogs badly in the first 1/3 of the throttle. This means that air screw and pilot will come into play.
The thing that has me puzzled is that it ran perfectly this morning. Nice and crisp and plenty of power. No bogging like now.
I think I will just muck around with the air-screw but can't see how it could effect it this much. .
Btw, yes I put a different ignition on. It worked fine this morning.
Old 04-06-2005, 01:27 AM
Kenny400's Avatar
Proud Papa
Aus,
I sent you a PM.
Old 04-06-2005, 02:13 AM
Mod From Down Under
Yep got it thanks Kenny. Sent you one back.
She's all good now!
The spark plug gap got built up with carbon. This must have happened because of using a batch of 16:1 premix!
Old 04-06-2005, 12:04 PM
Kenny400's Avatar
Proud Papa
She's all good now!
I LMAO when I read your PM. Your Dad needs to get his own gas can for the weedeater.
Glad to hear you found the problem.
Old 04-06-2005, 12:40 PM
MotoMan's Avatar
Floppy
Last Online: Today 08:39 AM
LMAO...I think I can guess what happened. lol.
Similar Threads for: Any Help?! ASAP Please!
Need Help Asap Riley_27 General Discussion 5 12-01-2005 10:12 PM
Need Help Asap! Riley_27 General Discussion 19 11-11-2005 08:35 AM
Blew up my DR 250, need help ASAP!!! dixienw123 General Discussion 18 12-13-2004 08:31 PM
Need yall's help, ASAP CRacer General Discussion 5 08-01-2004 09:58 PM
Help ASAP TixiLix General Discussion 2 04-05-2004 09:28 PM
