![]() Does anyone know where my air fuel mixture should be set on a 86 It 200 |
![]() wow that depends on a lot more than just a specific bike... elevation temp ect... Thanks Scott |
![]() its 65 degrees. were in michigan. whats the general specs? slightly seated er...one and a half turns er 2? |
![]() elevation from sea level... ect Thanks scott |
![]() were about 500 to 1000 feet above sea level ---------- Post added at 05:35 PM ---------- Previous post was at 05:34 PM ---------- our lowest point is 537 and the highest is like 1100 |
![]() then stock jetting should be fairly accurate... are you trying to jet for a problem? Thanks Scott |
![]() stock jetting??? ---------- Post added at 05:41 PM ---------- Previous post was at 05:39 PM ---------- were not changing any jets were just trying to find out how tight the air/fuel screw in the carb. is suppos to be at ---------- Post added at 06:17 PM ---------- Previous post was at 05:41 PM ---------- hello |
![]() Normally, the screw is about 1.5 to 2 turns out, but it does depend on the pilot jet. If the pilot is too small or too big, this screw could be way in or way out. Normally it is about 1.5 turns out. With the bike hot and idling, run the screw in until the motor starts to idle down, then slowly turn it out until the motor reaches it's highest, smooth idle. Reset your idle speed and you are done. If the screw ends up being turned out more than about 2.5 turns, your pilot jet needs to be smaller. If it is turned in less than 1 turn, you need a bigger pilot jet. This assumes the screw is behind the slide in the airstream. If it is ahead of the slide, then all this talk about the number of turns is exactly backwards. Scott |
Thread Tools | |
air/fuel mixture | tmxrider | 4-Stroke Dirt Bikes - Kawasaki | 0 | 11-18-2010 10:52 PM |
Fuel mixture screw | shovelhead | 4-Stroke Dirt Bikes - Yamaha | 1 | 04-15-2010 11:01 PM |
Yz 85 fuel mixture???? | yz85zak | 2-Stroke Dirt Bikes - Yamaha | 3 | 05-23-2007 11:32 PM |
fuel/air mixture | thoryamaha22 | 2-Stroke Dirt Bikes - Yamaha | 7 | 08-13-2004 09:56 PM |
air fuel mixture? | tailwhip | ATV/UTV - Yamaha | 7 | 12-23-2003 02:08 AM |
