99yz 125 problems
This is a discussion on 99yz 125 problems within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; ive had my yz125 for a couple weeks now and of the first couple rides everything was great. when i ...
Old 03-02-2009, 01:40 AM
Last Online: 03-16-2009 05:12 PM
Default 99yz 125 problems
ive had my yz125 for a couple weeks now and of the first couple rides everything was great. when i first bought it the rear shock would not recoil it was just stuck permanently down but the first ride i took with it it fixed itself somehow. it was the only problem and it fixed itself. i noticed that the rear sprocket had broken teeth so today i changed it out and tightened the chain a bit. Now the rear breaks will not disengage, the rear shock is stuck again and i cannot get off the front sprocket for some reason the rear tire just moves with it regardless. also the bike will not moove unless you are in high rpm but when the choke is on it will moove smoothly (regardless if warmed up or not). any help with the brakes/suspension/take off? also i was looking for a free download of the owners manual if anyone has a link
Old 03-02-2009, 06:47 PM
guess i came to the wrong place for help lol
Old 03-02-2009, 10:31 PM
MXtras's Avatar
Manufacturer
Last Online: 03-19-2010 01:59 PM
Your shock is toast. And your spring is suspect, too. Buy a new shock.
You replace the chain and sprockets as a set - not just the worn out rear sprocket and then tighten the worn out chain.
The sticky brakes could be from a bent rotor, sticky caliper, stuck pistons in the caliper or bad fluid return bushings.
The lack of take-off - way too many things this could be. Likely a combination of poor jetting, poor compression and/or weak clutch. Or it could be that you have no teeth on the countershaft sprocket. Or it could be that your rear brakes are stuck.
Too many questions in a single post, dude. If you want help, ask a single pointed question. Don't expect anyone to spend an hour trying to answer fifty questions. Be reasonable.
Good luck.
Old 03-12-2009, 08:11 PM
MXtras's Avatar
Manufacturer
No comment from anyone on the "bad fluid return bushings"???
I was hoping to get a chuckle, at least.
Tough crowd....
Scott
Similar Threads for: 99yz 125 problems
yz 125 problems cowasaki1 2-Stroke Motorcycles - Yamaha 5 09-03-2007 12:00 AM
01 Kx 125 problems hondafmx_89 2-Stroke Motorcycles - Kawasaki 4 03-07-2007 10:37 PM
Who's been having problems? cowboyona426 General Discussion 64 11-14-2004 10:46 PM
problems 250exking12 4-Stroke Motorcycles - Yamaha 20 09-17-2004 01:11 PM
GMB DVD problems? cowboyona426 General Discussion 14 08-24-2004 10:08 AM
