99 250 not running idlle Advise needed for newbie
This is a discussion on 99 250 not running idlle Advise needed for newbie within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; bike runs fine but does not run idlle, seems no idlle adjustment screw but electronic throtlle response system. Bike has ...
Old 04-15-2005, 12:57 PM
Last Online: 09-15-2005 02:06 AM
Default 99 250 not running idlle Advise needed for newbie
Bike has a spes pipe and silencer and boyessen power reeds.
New nicasil and piston.
Where to begin checking?
Old 04-21-2005, 09:51 AM
Default Re: 99 250 not running idlle Advise needed for newbie
Aah nobody here who can help or some advice where to look!
Come on help me out here.
Bike seams to be a bit lean 1/4 gas full throttle is ok but the engine will not run iddle.
Also there is no throttle stop screw on a 99? seems al other bikes have these
i only have the airscrew.
p.s. the throttle response electronic are working!
Old 04-22-2005, 06:35 AM
Aus_Rider_22's Avatar
Mod From Down Under
I set my airscrew by idleing the engine up(at operating temp) pretty high with the idle screw. Its black, kinda right above the airscrew. It might be different than on your carb, but probably close to the same area. Then I turn the airscrew "in"(clockwise) until it almost stalls..then I go the other direction until it begins to idle rough. In between those "conditions" it should reach a maximum idle rpm. You should be able to determine where that is by ear. That is what they call the "sweet spot". Then I usually go about a 1/8 to a quarter turn in the richer (clockwise) direction.
This info is from Kenny400.
Old 04-22-2005, 05:11 PM
Blue 250's Avatar
Last Online: 09-01-2007 03:28 AM
You probably have the idle circuit in the choke. Try turning the choke knob counter-clockwise and see if it helps.
Old 04-22-2005, 05:40 PM
Crazy's Avatar
Accident Prone
Last Online: 10-25-2009 10:00 AM
ya blue is right
Old 04-29-2005, 08:50 AM
i don't have a idle screw so it must be the idle circuit in the choke.
I will try this.
Another problem is that the bikes seems to be on the lean only 1/4 gas
Full throttle is ok and the sparl plug is coffee brown.
I own this bike for a couple of months now, put some boyessen reeds on it and a spes exhaust with silencer. What do i need to do about this?
Old 04-29-2005, 09:15 PM
robertc's Avatar
Retired...For Now!
Last Online: 07-19-2008 09:29 PM
Why do u want your 2 stroke to idle??? when it doesn't, its race tuned and you get the best preformance on the track. when ur warming it up, just wait a sec. and it will warm up in about 50 seconds. just blip the throttle andkeep it running. when i moved from a 4 stroke to a 2 stroke, it was different, but i have gotten used to it...i really like it better.
Old 04-29-2005, 09:51 PM
Mod From Down Under
You should be able to get your bike to idle.
I can see where robertc is coming from but I would think most people would want their bike to keep running without having to keep revving it.
When I go for a ride on my track I need to open and close a gate, and this means the bike idling by itself while I take hands of bars to unlatch the gate.
I guess it really doensn't matter whether you want you bike to idle or not, but for most it comes in handy, especially on the side of a hill when you don't want your bike to stall and have to kick it on the side of this hill.
Old 04-30-2005, 04:13 PM
Blue 250's Avatar
It sounds like a lean pilot jet. First try turning your airscrew in and see if it runs better. Something to remeber is that if have you turn in your airscrew more than a 1/2 of a turn from being closed go bigger on the pilot and retest and if you go more that 2 1/2 turns out from being closed, get a leaner pilot and retest.
Old 05-09-2005, 04:40 PM
shame on me .. can i read ...
the choke knob has 2 arrows on it and between them its says 'idle"
so simpel that i did not see it ...
So my bike idles ok now,
Old 05-12-2005, 01:31 AM
Mod From Down Under
Glad to hear you got it cleared up!
Old 05-12-2005, 01:50 AM
Kenny400's Avatar
Proud Papa
Last Online: 11-03-2009 12:35 PM
As I began to read that, I thought..."That sounds familiar!"
Old 05-12-2005, 05:13 AM
Mod From Down Under
Yeah, I should've probably asked about copying what you had said to me, but I thought he would want info ASAP and I did acknowledge the source.
Old 05-12-2005, 03:21 PM
say it come on say it .... I AM ..A ...
anyway, the enigine was running to rich, put the needle 2 clips higher and it runs much better now.
Thanks guys !!!!
Similar Threads for: 99 250 not running idlle Advise needed for newbie
Speedometer Advise Fireman87 General Discussion 4 05-17-2008 12:08 PM
Vintage racers I need advise P1M General Discussion 2 02-28-2008 09:14 AM
HI, new guy needs advise! Re: 1996 YZ125 hybridpower 2-Stroke Motorcycles - Yamaha 16 02-17-2007 10:27 AM
advise needed on throttle problem. VirginRider 2-Stroke Motorcycles - General Discussion 1 08-08-2004 09:38 AM
Parent Seeking Advise wikitori ATV/UTV - Yamaha 10 11-28-2003 09:46 AM
