97' 125 yz shift shaft replacement
This is a discussion on 97' 125 yz shift shaft replacement within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Hey guys new to the site, had a question for you guys maybe someone can help me. I ordered a ...
Old 07-17-2009, 10:54 AM
Last Online: 08-24-2009 02:45 PM
Default 97' 125 yz shift shaft replacement
Hey guys new to the site, had a question for you guys maybe someone can help me. I ordered a new shift shaft for my bike and am looking to replace it because the local yamaha dealer is a jerk. 1. I need to know how to get it apart to replace the shaft. 2. What are the seals called that I need to replace, and 3. what fluids do i need to fill back up. Thanks for your help and if im missing ne thing please humble me lol
Old 07-18-2009, 08:11 AM
MXtras's Avatar
Manufacturer
Last Online: 03-19-2010 01:59 PM
Simple job. First - clean the bike really well. Then pull the right side clutch cover, then pull the clutch basket. Now remove the shift pedal and clean that area well. Push the shaft through. Remove the seal and replace it. Push the new shaft in place and replace removed parts. Having a manual would definately help you if this is your first time inside the tranny.
You will need to replace the shift shaft seal and the clutch cover gasket as well as the powervalve cover gasket. You will have to drain the antifreeze and transmission fluid.
Sorry to be so brief - I am a bit short on time.
Scott
Old 07-18-2009, 12:27 PM
Default Thanks
Ok thanks man that def gives me a better idea of how to go about it. Also just curious of why you have to drain the anti-freeze? Also do you know a good place to order gaskets?
Old 07-19-2009, 09:47 AM
MXtras's Avatar
Manufacturer
Well - it's been a while since I was in a 97 but I think the antifreeze passes through the clutch cover into the case below the cylinder, but I could be wrong. Like I said- it's been a while.
I order my parts from several places, but try these guys:
Scott
Old 07-20-2009, 08:51 PM
Default Thanks
Ok thanks a ton Scott you have helped me tremendously. Have a good one.
Old 07-22-2009, 09:10 PM
Yikes, So I got into my bike, got the shift shaft put in, tried to get the gears and casing back on but something that goes into the top end right above the antifreeze drain thing...yeah it broke. Best to just take it to a mechanic now right? Not sure what that piece would be called.
Old 07-23-2009, 07:16 AM
MXtras's Avatar
Manufacturer
At this point, based on what we know you might be better off finding someone in your area that could come over and take a look for you.
Riding a motorcycle when you don't know how to maintain it can get really, really expensive.
Learn to work on it yourself - I have never met a bike that was able to outsmart me and I am sure you are a fairly smart fella. You just might need some guidance.
Scott
Old 08-12-2009, 10:34 AM
Hey Scott just wanted to let you know you were right! I fixed the bike last night. I broke the push rod assembly but had it welded back together and got everything back in. Now I believe I just need to eventually replace the powervalves (valve 1 & Valve 2) but thanks for your help again.
Old 08-12-2009, 01:10 PM
MXtras's Avatar
Manufacturer
Glad I could help!
Scott
Similar Threads for: 97' 125 yz shift shaft replacement
cam shaft tensioner kawamama3 General Discussion 3 03-12-2008 02:05 PM
down shift and up shift without clutch????? busaturbo15 General Discussion 11 09-12-2007 11:12 AM
shift drum replacement Michael Parker General Discussion 6 03-09-2005 10:58 PM
Replacing the shift shaft-xr50-How??? 4strkepwr660R Mini Motorcycle Riders 1 11-28-2004 12:18 PM
KX 100 Shifter Shaft Amanda 2-Stroke Motorcycles - Kawasaki 7 06-22-2004 08:01 PM
