96 yz250 powervalve adjustment????????
This is a discussion on 96 yz250 powervalve adjustment???????? within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; hi guys i recently brought a yz250 96 does anyone now how to adjust the exahaust valve as im using ...
Old 04-08-2009, 01:47 AM
Last Online: 09-13-2009 03:46 AM
readme 96 yz250 powervalve adjustment????????
hi guys
does anyone now how to adjust the exahaust valve as im using the bike in the woods and i need to calm it down a bit im trying to get a bit more torque.
i need the valve to open later in the revs if possible??????????
ive rode a rm250 for years and the power valve on that was easy to adjust
the yz iz much faster
Old 04-08-2009, 08:54 AM
Last Online: 11-19-2009 10:32 AM
Which year RM 250? Curiously - what was your technique for adjusting the power valve? Spring tension change?
Sean
Old 04-08-2009, 09:13 AM
MotoMan's Avatar
Floppy
Last Online: Today 08:39 AM
Originally Posted by xtchahos View Post
hi guys
I am not aware of a way to adjust them...I know you can buy different tension springs for the arm that comes up out of the case, but only from different year bikes....and I can't remember what years do what....been to long.
Try going up a tooth or 2 on your rear sprocket, or install a shorty type silencer, those work GREAT for more power down low.
MXtras's Avatar
Manufacturer
As far as I know, changing the spring is the only way to alter the actuation of the valve.
Have you thought about adding a flywheel weight?
You could also de-tune it a bit by using a thicker base gasket, or use two stock base gaskets.
Scott
Old 04-08-2009, 09:14 AM
MotoMan's Avatar
Floppy
Scott
Yes the flywheel weight is def a good idea as well!!
Old 04-09-2009, 01:37 AM
Sean
hey sean the bike was 88rm250 so u could adjust the valve from the
side of the head from cold 1 half a turn ani clockwise the power band would kick all the time and then a small turn at a time clockwise until u find the balance of power!!!!!
Old 04-09-2009, 01:46 AM
hi there that was good advice i changed the rear sprocket from a 49tooth to38tooth and the bike pulls through the gears now rather than pointing for the sky in every gear
wot kind exhaust would you think is best?????
thanks for your help
Old 04-09-2009, 01:51 AM
Scott
hey scott i dont know anything about flywheel weights????
do go heavy or light wot would u recomend ?????
thanks for your help!!!!
Old 04-09-2009, 06:32 AM
MXtras's Avatar
Manufacturer
Help with flywheel weights will have to come from someone else - I have no experience, sorry!
Scott
Old 04-09-2009, 08:42 AM
MotoMan's Avatar
Floppy
Well if you took teeth off the rear sprocket you actually just spread the gears out more making each gear longer. I was thinking you wanted more power on the low end, in that case I would look into flywheel weights for sure, that will tame the hit down even more.
Look at Dr. D's site for info on them.
Old 04-11-2009, 12:43 AM
Last Online: 10-11-2009 06:52 PM
I owned a 96 YZ 250 for more than a decade. Great Bike. I put an 11 oz Steahly flywheel weight on it for woods riding. Best mod I made on that bike. I left both sprockets stock. The flywheel weight is super easy to install, and the ones from Steahly come with instructions, and their customer service is excellent. I would highly recommend this mod for woods.
Old 04-25-2009, 03:48 PM
Default re:fly wheel weight
hi again i fitted a 11oz flywheel weight to the yz and man wot different bike to ride in the woods smother and lot more easier to use power and no stalling brilliant cant wait to get back out on it again
thanks for a great bit advice.any other good mods u made???
regards paul
Similar Threads for: 96 yz250 powervalve adjustment????????
YZ 125 Powervalve Q.. Kidafa 2-Stroke Motorcycles - Yamaha 3 11-06-2008 08:29 AM
Yz 125 Powervalve ? ktm125man 2-Stroke Motorcycles - Yamaha 1 11-11-2007 09:38 PM
1989 YZ250 Float Adjustment MotoRyder 2-Stroke Motorcycles - Yamaha 2 10-25-2007 12:38 PM
powervalve camestr 2-Stroke Motorcycles - Yamaha 5 08-04-2007 06:00 PM
2002 cr125 powervalve adjustment taramoto 2-Stroke Motorcycles - Honda 0 04-30-2007 06:48 PM
